Happy new year all!
For the new year, I'm looking to purchase a decent tube amp and need a little bit of advice. Ultimately, I am looking for something which sounds great clean but can
also do nice over-driven tones (doesn't need to go too heavy as I only
play blues and not to hard core rock). My budget is £800
Currently I have narrowed it down to the following amps for home use:
Vox AC4TV - can do 4w, 1w and .25w
Marshall 1 watt anniversary series - JTM1C - Plexi tones with 1w and 0.1w
Cornell Plexi 7 10inch - can do 7w, 1.5w, 0.25w and 0.125w
Fender Blues Junior - Rat modified versions can power scale.
Also considered the Blackstar HT1R but not really a fan of the tone.
I've done a fair bit of research (reviews and youtube), but can't find these amps locally to try! (Either be sold out due to Xmas or niche).
Has anyone used any of these amps at home? Are they suitable? Are there any other power scaling amps I should consider?
Many thanks!
Edit: I thought I should make it clear, that the amp is really only for home use as I don't gig/perform and I don't really want to have to use a separate attenuator if possible (ie I'd prefer amps with built in power scaling or already modded)
It's only 0.5W (max distorted) but through a decent speaker it's surprisingly loud and has a nice clean sound, although overdrive is really what it's designed for. The only problem with it is that the cooling fan noise can be irritating.
I was very disappointed with the 1W Marshalls, the Vox AC4TV sounded poor to me, and I don't like power scaling. Likewise I didn't like the Blackstar HT-1R enough to buy it, although it was actually the Blackstar I've disliked the least!
I sometimes wish I hadn't sold my original Nano, and I can't really justify the price of another one unfortunately...
Which 1w Marshalls have you tried? I have seen videos and a lot of the recordings are underwhelming, so it's really hard to judge.
soundcloud.com/thecolourbox-1
They're also not well enough made for the ludicrous prices they were when they first came out, although at the clearance prices (after two years the big dealers were still trying to get rid of them, which says it all really) they're maybe not so bad. But they just sound 'small' to me - I know they're only 1W, but they just don't sound loud or full even at that... I know what 1W can sound like through a good speaker, and these amps do not. The Blackstar totally blows them away, if you don't mind the actual tone!
Still, overdriving the AC4 a bit or running it clean-ish and adding an overdrive pedal is a thing of a beauty, especially with single coils!
Thanks, maybe I need to revisit the Blackstar and play around with the controls more. I agree regarding the prices, they seem to be still pretty high in the used market.
Thanks, I know that the tone is usually better when the amp is pushed a little more and that power scaling affects this. There's just nothing like a cranked/pushed tube amp going into overdrive, unfortunately it's a massive challenge at lower volumes. I still need to find an AC4TV to try - I'm surprised its out of stock in Brum as I thought it would be a good seller.
Thanks, I agree with the prices and build quality. Perhaps I need to revisit the Blackstar and play with the controls more...
Thanks, I agree, the AC4 is nice. I just have to find one locally to try, I've been surprised that its not been in stock at some of the stores locally. I know that power scaling with affect the sound, but it appears to be the only feasibile way of getting a decent overdriven sound from a tube amp at home. There's nothing quite like an overdriven/cranked amp... only challenge is to do it a sensible volumes.
I used to have the Vox ac4 and personally didn't like it that much. I think fairdeal in Birmingham normally have them but I could be wrong
For me personally the AC4 sounds quite congested and boxy, and worse when set to the lower-power modes, but that's a reflection of the very basic type of attenuator it has, and not all attenuators.
For me personally, given your budget I'd actually look for something like a used Mesa Express - bigger amps with proper EQ and good master volume controls can sound far better at low volume than cranked micro-power amps, to me. The idea of amps being "too loud" to use at home just because they are *capable* of being is something I just don't follow really.
Yes absolutely this, although I imagine space is a consideration for the OP? Like my Princeton is fine at home with an attenuator sound wise but I've nowhere to put it in my spare room
5w but it’s great.
http://www.thefretboard.co.uk/discussion/114497/danplifier-matchbox-3w-high-gain-amp-now-with-video
If the latter, Yamaha THR or Fender Mustang GT40. Perhaps a Katana Mini but I’m yet to hear one myself.
If the former....literally anything else
I got mine off ebay for about £200.
Having said that, the Danplifier does looks really good.
This?
This?
