So help me out guys...
I've been playing for about a year so still a beginner but I wanted to add a bit of sound variety to my playing so started looking at what pedal(s) I might get. Bit of a minefield for a newbie but then someone pointed me at the Line 6 Helix LT. I've got a nice amp that I'm happy with at the moment (Corso), but it seems that my options are either to start a pedal board or to sell the amp and get the Helix LT plus some speakers.
A couple of things that's pushing me towards the Helix is that it's a much tidier solution and that I can probably replicate (near enough) every sound I'm likely to want to try and reproduce, especially with the help of some IRs.
Given my current position, which way would you go?
i have a Helix but I wouldnt have had a clue what I was after sound wise when I’d only been playing a year.
1) Buy at least 10 very expensive pedals ......keep swapping them around and the sequence order on the board
2) Realise that you actually need 2 Power units.....so spend some more money
3) Realise that 10 pedals suck tone and become somewhat disturbed
4)Realise that you need a Loop Switcher / Isolator
5)Spend £1000 with gig rig on a switcher , cables, distributor etc
6)Decide to sell some pedals, take a loss and buy 4 or 5 alternatives
7)Play a mates Helix and realise how easy and efficient it is
8)Sell all pedals ,make substantial loss ,sell loop switcher make even bigger loss
9)Buy Helix and realise Amp not needed
10) Sell amp; more loss
11) Buy expensive FRFR cab/ monitor
12) Buy back one or two pedals to put in the loop..........just for old times sake
13) start enjoying pedals in loop but questioning if Helix doesn't make it all sound a bit too digital
14) Sell Helix and FRFR cab ......sustain the immense loss bravely
13) Hunt down "the Amp"
14)Pay more to buy back the old pedals
15) Get sick of all the wires and cables because you're sure as hell not going down the expensive loop switcher track again
16) Your mate sold his Helix and got a Kemper.......you listen in Amazement and Wonder
17) Sell all and buy Kemper and hunt down another FRFR cab or Maybe go for the 4 cable method
18) Etc ETC,ETC
Now you're just getting started........WELCOME TO THE FRETBOARD !
As advised get a couple of cheap drive pedals (e.g. Nobels ODR1, digitech bad money, boss sd1) and something like the zoom multistomp for delay, reverb and maybe chorus.
This will help you learn about how pedals work, how to stack gain pedals, what type of delay you like etc etc. The above pedals and a one spot power supply should be less than £300 if you buy carefully and or second hand.
edit: decide on your budget before looking and try to stick to it
A multi FX like zoom or an old line 6 m9 would probably be better.
I was in a similar situation years ago, and I got guitar rig software. Was massively overwhelmed.
https://www.boss.info/global/categories/stompboxes/
Adding the same pedal in different places in the chain on the Helix is quick and easy and you can see what difference it makes to you. It also allows you to understand the differences between types of OD, compressor, delay, reverb, modulation, amp and cab without having to purchase and store all that kit.
There is no right and wrong. I still love pedals and amps, but the Helix inspires me more and encourages me to think more creatively. I don't obsess over the precise tones beyond a point - I mean, its obviously got to sound good to my ears, but that's where it ends. So the speed of setup, flexibility of sounds and ability to play through headphones works really well for me.
The Corso is a killer amp - perhaps use that with the new Line6 HXFX to still have the flexibility of pedal ordering etc whilst retaining a stellar amp?
My music:- https://soundcloud.com/hubobulous
It's what made me sell my helix the first time I owned it.i really thought it sounded arse bag awful through my hiwatt and that makes any pedal sound great.
(See what happens when you ask a question on a forum, everyone has a different answer)
Spend a day in a shop that has a fairly decent pedal selection and see what you like. Buying used will obviously get you a lot more for your money.
Most and foremost play your guitar, don't get caught up in gear, be more focused with playing the things you love
If I were to get some 'starter' pedals, what are your thoughts on the Behringer ones? They seem to be available for around £20 new, which isn't the end of the world if I don't get on with them
As an aside, how is the Line 6 m5 viewed? I know it can only do 1 effect at a time but I wondered if it might be able to cover a few bases without breaking the bank
Joyo ocd is a good shout, it's a bit noisy but it's cheap
I would echo go mooer over behringer. Tc electronics have a cheap range of pedals too that are alright
Taking on board the comments above, I've gone for a Zoom G3XN that was for sale in the classifieds. Hopefully it will give me a little of what I'm looking for and with any luck I'll learn something. And in the grand scheme of things it was pretty cheap.
Once again, many thanks for the advice chaps
I think they are not all great though - check out the individual reviews.
Whilst it's massively overwhelming to me at this stage, knowing I have the ability to get pretty much every sound I could want out of one bit of kit is great.
What I like is that it doesn't have to be overwhelming. The day will come when I will want to endlessly tweak everything to the nth degree, but for now, when I'm trying to progress in my lessons, it can be as simple as you want and you can get good tones in seconds.
