So I'm desperately searching for ways to weight relieve it. I'm thinking perhaps routing out the area covered by the pickguard. Also if conventional single coils are significantly lighter that's an obvious option...
Come on guys help me out here - we're all guitar geeks
http://www.mundomusicgear.co.uk/pain-free-guitar-strap/
The lightest guitar you’ll find is either a pre facelift Parker Fly or SG
Weight would only start being significant if someone started making their pickups out of extraordinarily heavy or especially light materials- you know, black holes, or fairy jizz and such.
If you want a light guitar then look at Steinberger, Canton, Forshage, Strandberg headless designs.
https://i.imgur.com/95kAjQ2.jpg
https://i.imgur.com/fBHYarB.jpg
It was inspired by the Guthrie Govan guitar but I wanted three single coil pickups. It actually goes one step beyond the GG in that the headstock is backangled - meaning no string trees which makes it even more tuning stable.
22 frets - so the neck pick up is that the second octave (if that actually makes a difference I don’t know, but I like how it sounds).
It has everything, including a contoured heel and rear chamfering of the lower horn to facilitate access to the dusty end of the fingerboard.
Is there anything practically do-able to reduce the weight? Given the unusual nature of the bridge, I can’t very well buy a light / chambered body off-the-shelf...even Warmoth will only do a routing for recessed full-size Floyd and that will leave an unsightly gap behind the locking screws tuners.
If not, my advice is "Do" !
Completely routing out the area under the pickguard will make a bigger difference, but it will very likely also change the sound of the guitar quite significantly, so I would be careful.
A chap I used to know once bought a 1979 25th Anniversary Strat - which usually weigh about as much as a car - and it was a quite reasonable weight and sounded somehow ‘airy’ and almost semi-acoustic. When we took the pickguard off, it was! It had been chiselled out for three humbuckers and a pedal circuit .
It can be surprising how little difference in weight is noticeable, although whether it will make enough of a difference to help, I don’t know. The balance of the guitar also changes the perceived weight quite a lot - lightening the body will make the weight shift more towards the neck, which may not be a good thing. If so then lighter machineheads may help - those are cast-body ones, which aren’t that light.
A good strap makes a huge difference to perceived weight.
Which reminded me I’ve been meaning to weigh the Fluence Classic bridge I have as I’m sure it’s lighter than my other humbuckers.
I was correct but it’s not by much.
EMG 81 = 130g
Fluence Classic = 105g
I’d guess that it’s going to be even less difference between typical single coils.
