Les paul low end flub
daveyhdaveyh Frets: 684
So, I’ve always had a problem with the sound of Les Pauls, low E fifth fret and below it’s gets .... flubby. What causes this and how do you fix it? Pickups? Amp?
  • LebarqueLebarque Frets: 3876
    Get a strat
    10reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • richardhomerrichardhomer Frets: 24812
    edited March 2018
    In anything which is Blackface Fender-like - which tend to have an extended bass response - it seems to be an issue. Through my Mesa Lonestar Special, a Les Paul needs a lot less bass than other humbucking guitars.
    Through Tweed and Marshall based amps, it seems to be much less of an issue.
    I don't have the luxury of playing a variety of real classic amps but I do use a modeller pedal (Amplifire) which is generally seen as sounding fairly realistic.
    I find playing a LP through one of the Fender modelled amps causes massive boominess but when switching to a Marshall model the bass end is far more tamed.
    I wonder how Joe Bonamassa does it since he seems to play a Gibson through a Fender more often than not
  • TimmyOTimmyO Frets: 7437
    How high/low are the pickups set?
    Red ones are better.
    A high pass filter would be able to dial out a flubby bottom end and tighten up your sound. Or use a suitable eq pedal to do the same thing.
  • Lebarque said:
    Get a strat
    ...Said nobody ever.
    2reaction image LOL 0reaction image Wow! 3reaction image Wisdom
  • sweepysweepy Frets: 4184
    PAF pickups and good clones have a lot more clarity and definition than most of the pickups fitted to recent Les Paul guitars, I certainly haven’t noticed this with my LP Trad and OX4 pickups
    This. I was astonished by how much difference correctly setting pole piece heights and the height of the pickups from the strings made to the tone of my guitar.
    There are loads of tutorial videos online & best of all it's free and totally reversible-
    I used this article:
    https://www.premierguitar.com/articles/22114-mod-garage-humbucker-height-adjustment
    definitely give it a go before spending any money or rewiring anything.
  • stickyfiddlestickyfiddle Frets: 27105
    What pickups?
    Is it both pickups bringing the flub?
    What is the rest of the signal chain?
  • Since other people have covered pickups my questions are:
    What is your usual main guitar?
    Are you trying to use the same amp settings for that guitar and your Les Paul?
    If lowering pickups doesn’t help the next free thing to try would be just turning the bass down lower at the amp.
  • crunchmancrunchman Frets: 11453
    Doesn't he use tweeds. Much more mid-range.
    Get an EQ pedal and start to roll of some bass frequencies until it tightens up the sound.
  • ICBMICBM Frets: 72415
    They do that. It’s what makes a Les Paul great and anything else that’s touted as being as good as a Les Paul not great. Nothing else quite has that massive bass thump...
  • mrkbmrkb Frets: 6879
    I love watching Dirk Wacker videos.......
    Karma......
    Ebay mark7777_1
  • daveyhdaveyh Frets: 684
    I’ve always put the low E side of the neck pickup level with the ring and then matched everything to that.
    Ive always had this problem with LPs, whatever amp I’ve been using. But the vast majority of LP sounds I like are customs, and atm I have a killer 2001 studio. Maybe my ears are just expecting something different?
    It sounds like it's the opposite problem to the one I have with Strats. Many of my favourite recorded sounds are Strats, a lot of my favourite players used them almost exclusively, and they sound fine... but whenever I play one they sound a bit thin.
  • BucketBucket Frets: 7751
    That shouldn't be the case - LPs should certainly have a bigger than average low-end presence, but never at the expense of other frequencies. They should have some amount of top-end spank as well - I once heard Pete Thorn say that the best Les Pauls sound a bit like big, fat Teles and I think there's something in that.
    Try lower-output pickups. If you're using high-output pickups they'll be more compressed and will probably sound darker and flabbier - I've been fortunate enough to try an original PAF in the bridge position of a well-sorted Les Paul and it was a revelation.
  • VoxmanVoxman Frets: 4724
    My LP is a 1990 Custom and I can't say I've ever had any such problem as the OP. In fact I'd say the bottom end is pretty tight through all my amps.
  • All mine have been tight in the low end too, to the point where I try to get my other (non-LP)  guitars sounding as good as the Les Paul does, because the others I have don't get anywhere near as tight.
    Other frequencies aren't losing out, its just that theres too much low end on the low E, first 5 frets or so. I do like the idea of a big fat tele though, that would be something to chase.
    Agreed to the lower output pickups, although choosing could be a problem as I'm thinking LP standards It's Slash, Perry, Gibbons are quite varied.
