Hi folks.
I got myself a Charvel Pro-Mod San Dimas late last year and it's a fantastic guitar. I just want to play it all the time and can never put it down once I start. But there's one thing that's got me thinking if there's a way round it... Drop D tuning. I really like the Floyd and after two string changes I've got the hang of setting it up and all that, but I'm feeling like I want to use it to play some stuff in drop D (and maybe even drop C or C#). I like the Floyd, my only real niggle is being fixed in one tuning, although I don't do very much that's not in Standard to be fair... so far anyway.
Please excuse the Rookie questions, but a lot of this is new to me.
- Would a Tremol-No let me change tunings if it's set to locked? I assume I just loosen the nut and use the machine heads?
- What are the drawbacks of a Tremol-No (I've read on here about them being notchy feeling, for example)
- Is there a better option than a Tremol-no? Maybe I just block it with some wood and abandon using the bar, which barely ever gets used anyway.
- Am I better trying to set the guitar up with the low E fine-tuner set so I can drop a full tone by winding it right in / out? (Is that even do-able?
Any experiences at all with this sort of thing would be really helpful. On the face of it, the Tremol-no can do it all and would let me swap tunings, but it seems people have mixed feelings on them. I looked at a D Tuna, but my bridge is floating so they don't seem to work for me.
Cheers.
Andy
4 - You can get a Floyd into Drop D even without a D-Tuna, if you start with the fine tuning screw most of the way down for E, there's usually enough travel. Further down that that will mean undoing the locking nut, and the Tremol-No probably won't hold tightly enough to cope with that.
2 - The main drawbacks are that it doesn't hold tightly enough in general anyway, tends to slip, rattle and generally misbehave. The problem is that the engineering isn't quite robust enough to handle the forces involved - the little thumbscrews can't be tightened enough to grip properly.
3 - If you want lowered tunings and aren't bothered about locking it for double-stops, a simple backstop device will work much better - either a proper one, or almost anything screwed to the trem spring cavity floor so that it contacts the front face of the block and stops it moving forward. This will also allow the bridge to move normally for downbends.
Google image search 'tremolo backstop' for a range of options, including some amusing DIY ones... but which will actually work.
i have one fitted to my floydy guitar.
My my trem is still floating but the little gizmo below only let the trem dive bomb, it stops the trem from pulling up so the change in string tension doesn’t effect it.
Ebay about a tenner....
Net result is the Ibanez stays in std tuning. I use my Tele deluxe for drop tunings.
Which seems a bit back to front I'll admit!
A 3rd guitar will solve all your issues here... heheheh
Basically set the fine adjustment screw so that you have enough travel to detune the low e to d.
It worked, but I never did it often or kept it that way for long to know if it could cause any other imbalances per se.
When I checked the previous threads on here and googled a little, this query seems to be a perpetual issue for folk.
Love your SG by the way!
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F141825338522
http://www.lonephantom.com/wp-content/uploads/2012/02/20120204-183746.jpg
Oh, and D Tunas look to be hard to find and quite a bit dearer than I thought they'd be. I'm gonna be in the US soon, so might keep my eyes open for one in a Guitar Center or something.
I do I don't bother with a D-tuna and manage by just adjust the Floyd so that the low E can be slackened off to D.
The great thing is that it can be removed without leaving any evidence of it being there.
I may end up looking at the D Tuna later, but step one will be to try the bracket setup. Fingers crossed.
