I'm deciding on what wiring on a 2 HB guitar to do.
It was previously a bit over done with 4 mini switches for coil splitting series, parallel and out of phase. I'm looking to simplify things down to a 5-way (and one switch for coil splitting both HBs at the same time.
Originally I was going for a 4-way with the standard bridge / bridge + neck (parallel) / bridge + neck (series) / neck.
But then I thought, if I'm replacing the 3-way, I could put a 5-way in and get an extra mode.
So, within a standard 5-way ( not a superswitch) what else could I squeeze in? I don't want any additional coil splitting. Is there something else I can do to vary the way the two pickups play together?
Can't sing, can't dance, can handle a guitar a little.
About the most you can get is:
1 - neck humbucker
2 - neck humbucker + split bridge
3 - both humbuckers
4 - bridge humbucker + split neck
5 - bridge humbucker
To do this you use the standard 'Tele' wiring scheme with the pickup hot (full) outputs connected to the rotors and the volume control connected to the four switch terminals, then connect the two coil splits to the unused contacts so the neck split is selected when the switch is in the bridge position, and vice versa.
A damp cycle home got me thinking. Perhaps something like a jaguar's bass cut would be interesting. It looks like the signal from one of the pickups needs to be fed through a capacitor. I've not worked it out but I think that it should be possible to add both pickups with a capacitor to the fifth position. A jag uses a 0.003um cap. Would HBs need a different value?
Bridge, Parallel B&N Partial Out Of Phase (Donahue wiring), B&N Parallel In Phase, Bridge Humbucker & Partial Split Neck, Neck Humbucker.
A push pull on the tone control does partial splits on both pickups.
I also added a 470k resistor in parallel with a series connected 470k resistor and 0.022uF capacitor on position 3. This (in theory) makes the split positions 3 & 4 subtly different but I can't really hear it.
- Bridge HB only
- Inside Coils Parallel (Strattish)
- Inside Coils Series (Brian May-ish)
- Outside Coils Parallel (Meh!)
- Neck HB.
For noise-cancellation reasons, the bar magnet in one of the humbuckers needs to be reversed.I prefer the Ibanez HH circuit. Various versions of a five-way switch with bespoke PCB tracks offer;
I have guitars with unbelievable numbers of combinations and permutations of settings - and I spend hours happily messing about with them in home practice. But I confess that in live situations, I almost always end up with the standard 3 way options plus coil splitting one or other of the humbuckers (and never both, in reality) to add a bit of brightness in the mix if it's a bit PA-bassy.
So, the plan is to try and pick something simpler. The 5 way option @icbm suggest above does appeal to me (if I can work out how to wire the switch). I think that's most likely what I'm going to go for. Better get the order sorted out. Cheers for all the input.
