As it’s not been played for a while I’d say a set up would do it the world of good
If it was a defect string then it would only be one string itself
If a neck relief issue then I'd expect buzzing on far more frets, ditto with to low an action
Not sure if you can see it has lifted when you look at the fret - Sometimes can be tapped back in - Use small block or lollipop stick and gently tap back in - If this doesn't work then it will be work for a guitar tech to replace accordingly
Firstly i I would take the guitar to be set up for your needs. All new guitars I have ever bought have needed that right away. If anything it will improve your happiness with the guitar immeasurably.
Ps, strats sound great with the amps you have but buy a fuzz and you will be grinning from ear to ear.
If the frets pass the rocker tool test, then, the fifth fret is not high and the fourth is not low.
Choking towards the nut end of the neck suggests incorrect truss rod relief adjustment.
If the guitar was set up for 10-46 or 10-48 gauge strings and, then, the tension dropped, the relief will need resetting. 9-42 strings would create insufficient tension against the truss rod. So would tens if the guitar is drop tuned to Eb.
The guitar has in no way been messed with or fettled since I bought it new so the problem must have been there from the get go.
It may well be that there’s not very much at all wrong with the guitar that a Setup won’t sort.
Did you adjust the neck so that it was flat when you did this? I believe the tool for this is called a notched straightedge. If the board isn't flat, then you can't tell if the frets are the same level or not.
Bandcamp
Remember, righty tighty lefty loosey.
contactemea@fender.com
