Can you put a tele neck on a strat (or vice versa)?
I've got some pickups I bought on here a long time ago, that never made it into the guitar they were intended for - I've been vaguely thinking about getting a body and neck and hardware and cobbling something together, and I was wondering if I got a body that used to have a Strat neck on and a Tele neck (or the other way round), would it work or would I have stupid intonation problems? Or other stupid problems?
  • GrangousierGrangousier Frets: 2645
    (Now I search again, I see that essentially the same question was asked on April 1. Sorry, chaps, I'll be over here hanging my head in shame.)
  • ChalkyChalky Frets: 6811
    If we couldn't ask the same question twice on here, this place would be Tumbleweed City in a day or two! :)
  • Looks like OP is sorted, but in case anyone else stumbles upon this thread looking for the answer, it's no.
    A Tele neck has a square heel whereas a Strat neck has a more rounded heel:
    https://goo.gl/images/6edpqt
    You can stick a J neck on a P body though?
  • blobbblobb Frets: 3014
    Deke Leonard had a strat neck on his bullseye telecaster. In his own words:
    "..it did once have a strat neck because when I was with The Corncrackers In the early 1960s the Tele and myself were electrocuted and the strings fused/melted into the neck (along with my hands). At the time I could only find a Strat neck to replace it. Then later, I managed to get a Tele neck refitted. We came through a lot, the two of us."
    Feelin' Reelin' & Squeelin'
  • DrBobDrBob Frets: 3007
    You can put a Strat neck on a Tele, you just end up with little “teardrop” shaped gaps either side because of the rounded heel in a square pocket. If you use a 22 fret neck with the 22nd fret on the overhang that covers up the gap.
    The one that doesn’t work without modification is a Tele neck in a Strat pocket,And in fact I’ve recently seen a couple of Strat bodies where they haven’t routed the back of the pocket to match the curve of the heel, they’ve over-routed it with a really big diameter bit with only the pick guard on top defining where the neck actually sits
