A Tele neck has a square heel whereas a Strat neck has a more rounded heel:
https://goo.gl/images/6edpqt
Soundcloud: https://soundcloud.com/iainflockton
"..it did once have a strat neck because when I was with The Corncrackers In the early 1960s the Tele and myself were electrocuted and the strings fused/melted into the neck (along with my hands). At the time I could only find a Strat neck to replace it. Then later, I managed to get a Tele neck refitted. We came through a lot, the two of us."
The one that doesn’t work without modification is a Tele neck in a Strat pocket,And in fact I’ve recently seen a couple of Strat bodies where they haven’t routed the back of the pocket to match the curve of the heel, they’ve over-routed it with a really big diameter bit with only the pick guard on top defining where the neck actually sits
