this is probably just me but.....
whenever I see an ad for a vintage ( or any for that matter ) guitar and it has been taken apart i.e. neck taken off, guts on show, pick ups although still attached hanging upside down out of the guitar it makes me squirm. This is always bolt on type guitars and I know it's to prove age and originality but I think once put together in the factory they should stay put together. To me it's like having a new car and then it gets it's first ding or crash and then you never quite feel the same about it again..? I know these guitars were designed to be taken apart so necks and bodies can be replaced but I think maybe the guitar will never quite be the same again once it's been seperated and put back together..?
like I said...probably just me and I'd love a birth year guitar ( 1966 ) but this always puts me off buying one...maybe someone can settle my nervousness on this...
- “To play a wrong note is insignificant; to play without passion is inexcusable.”
It has never, ever sounded or played any differently any time I have done it.
So long as you take care and use good tools, there will be no change afterwards.
Strangefan said: I definitely don't want one then....!!
Bridgehouse said:
Again...just my own weirdness about this...
If it’s been played a lot over the years but not even had the guard off then it raises questions about maintenance and cleaning pots etc for good playing
If it’s sat under a bed for 50 years then I would want electronic and mechanical parts checking and maintaining.
Or do tou just want it to look at? If so - original strings on it? Maybe even the case never opened?
I make my own pickups for my guitars and I can honestly say they sound just as good as any old Fender pickup in fact I sold my custom shop 59 because of this fact. That's not be bigging myself up, it just made me realise that essentially a decent pickup is copper wire and magnets that is all, no mojo no fairy dust just a bit of skill to make sure you get a nice voice.
Having owned quite a few, vintage for me comes down to one question - do you want to play it or not?
If not, then fine - put it in a glass case and leave it. If you do want to play it, then it needs maintaining as bits wear out and break, and adjustments need to be made - and as such having vintage guitars with bits of guts spilling out all over the place from time to time becomes the norm...
If I bought a vintage guitar I would gig it...I don't believe in guitars just hanging on the wall or in glass cases to be looked at every now and again...but as I've said my gut feeling is that once taken apart a guitar would never quite be the same.. like many things there is no proof or rhyme or reason to my thinking...it's just my observation on something..
One mistake a lot of people make is not to preserve the original screw positions - this sounds very geeky, but if you put things like the pickguard screws back in the wrong places, the pattern of corrosion on them doesn't look right and it's very obvious that it's been had apart. I always set the screws down in the shape of the pickguard as they come out, so they go back in the same holes. (And the same with the other sets of screws.)
One of the chaps at the shop has made a little wooden block with holes drilled in it to make it easier, I should probably do the same.
"Don't look, Ethel." Ray Stevens
Stripping down vintage Fenders is a necessity, and usually they play better after a tuneup ... not worse. I'm assuming the OP wouldn't feel comfortable with a refret either ... in which case his hypothetical vintage guitar becomes unplayable with wear ... that's it ... it's the glass cabinet or landfill, as all the mojo would get thrown away with the knackered frets! :-).
If I could remember the exact quotation, I would have used the Tommy Cooper joke in which he complains to the doctor that doing something or other hurts. The doctor replies, "well, stop doing it then."
i took my first guitar apart within a couple of months... not stopped since then.
Instagram
