Guitar wall hangers
lincolnbluelincolnblue Frets: 294
I'm after a couple of guitar wall hangers. I'm tempted by Hercules ones but can anyone recommend any good alternatives. Don't want to spend more than about £12 per hanger
  • meltedbuzzboxmeltedbuzzbox Frets: 10340
    Get hercules. They are the best
  • impmannimpmann Frets: 12687
    This.
    I've got a good few of the Hercules ones I could sell you for cheap, just need to work out what the postage would be but won't be home tonight.
  • lincolnbluelincolnblue Frets: 294
    Sounds great. Thanks
    @thegummy ;Sounds great. Thanks
  • BoopDeWoopBoopDeWoop Frets: 101
    Not sure why people would scrimp on buying a wall hanger. £12 vs £8 on a guitar that I'm assuming is >£500 seems daft.
    Just this afternoon I've mounted four of my guitars on my wall using the string swinger type- about £24 per pair seemed super reasonable and they're reviewed super well. A doddle to put up onto my plasterboard wall too.
    Have you got a link the them?
    edited July 2018
    I bought these ones. Just within your budget actually- the cheaper ones all seem to have some negatives and these look much higher quality.
  • JezWyndJezWynd Frets: 6121
    You're missing a colon. :o
  • skunkwerxskunkwerx Frets: 6885
    Buy the hand ones so we can have a giggle!
  • WazmeisterWazmeister Frets: 9627
    Bang on and fautless. Rock solid.
  • NiteflyNitefly Frets: 4933
    K&M 16280 for me - I have 6 in my mancave, rock solid and won't damage nitro-finish Gibsons.
    These:
    https://www.amazon.co.uk/Konig-Meyer-16280-000-55-Holder-Guitar/dp/B000N5HU5A
    What is the wall made of?  If it's masonry (brick or block) you'll be fine with rawlplugs and woodscrews, but you'll have to take more care if it's plasterboard.
    The wall is plasterboard but I have decent Rawl plugs
  • guitars4youguitars4you Frets: 14470
    100% agree - I hang 5K or 10K guitars of mine and they won't mark - I've seen other hangers mark the finish - So go with Hercules - end off - Just make sure appropriate fittings etc based on what they are mounted to
    Fixed, not like I typed the whole URL out by hand though...
  • Electro_HamElectro_Ham Frets: 102
    These:
    I use these as well. I can't fault them.
  • paulmapp8306paulmapp8306 Frets: 850
    hercules for me too.  I have my Martin, PRS CU22, Suhr Modern, Select Strat and Tom Anderson all on those.  No issue at all.
    Anyone who has the Hercules ones with the wood - any suggestions of what kind of packaging I could send some in?
    Reckon a bubble envelope would be okay or better in a box?
  • fretfinderfretfinder Frets: 5078
    I’ve been using the String Swing wooden block ones for 15+ years and never had a problem. They’re supposed to be nitro-friendly but I don’t take any chances and put a cotton sleeve over each of the prongs.  :)
  • LegbaLegba Frets: 2
    I have some guitars on wall hangers... normally my less exspensive ones.  I am always a bit wary on what a wall hanger can do to a guitar?  If you go by the saying that you should never treat a guitar in any way that you would treat yourself... i.e. would you hang yourself by the neck to a wall?  Anyone ever heard of a guitar/neck being damaged by hanging its dead weight by the neck?
    "Oh, I can get us there real quick!"
