I'd presume it's because the ground is somehow isolated. There are such things as ground isolators admittedly, though I've an Orchid Electronic one and more recently a Behringer Hum Destroyer, and neither really worked. Both reduce my signal level significantly, and the Behringer seems to now make noise when I DO touch the strings, rather than when I don't (can't remember if this was the same with the Orchid).
With all this said, I'm not sure my noise is the same as 50 or 60 cycle hum so maybe my findings are irrelevant.
soundcloud.com/thecolourbox-1
