Wireless systems and 60 Cycle Hum
nutsngumnutsngum Frets: 28
This is more than likely a daft question, but does anyone know if using a wireless system gets rid of the 60 cycle hum experienced when using p90s and single coil pickups?
I have a TVL Jazzmaster and I love it, but it suffers a bit from this, though strangely, not as badly as some of the other JMs I've tried at twice the price.
  • ICBMICBM Frets: 72924
    No. The hum is picked up directly by the pickups, and is affected to some extent by the wiring layout and the shielding in the guitar, as well as the exact type of pickups. A wireless system simply transmits the signal from the guitar.
  • nutsngumnutsngum Frets: 28
    Ok mate, cheers.
  • crunchmancrunchman Frets: 11501
    The pedant in me has to point out that the hum as at 50Hz in the UK not 60Hz.
  • I'll put a Spaniard in the works. I've always had terrible noise issues with my guitars (two different houses, several amps, single coils humbuckers and other misc pickups) and the only thing that has ever solved it satisfactorily is a wireless system. I have a crappy Shure thing that eats batteries in the sender and the receiver is A5 paper sized, but it kills all the noise problems I've had.
    I'd presume it's because the ground is somehow isolated. There are such things as ground isolators admittedly, though I've an Orchid Electronic one and more recently a Behringer Hum Destroyer, and neither really worked. Both reduce my signal level significantly, and the Behringer seems to now make noise when I DO touch the strings, rather than when I don't (can't remember if this was the same with the Orchid).
    With all this said, I'm not sure my noise is the same as 50 or 60 cycle hum so maybe my findings are irrelevant.
    soundcloud.com/thecolourbox-1
    Interesting. I'd sort of assumed because you were essentially removing the direct connection to ground that the hum would no longer be a factor, I'm going to try and pick up a Boss WL 20 when they finally arrive and give it a blast anyway.
    Every day's a school day
