Combo, Heads and cabs
hotpickupshotpickups Frets: 1822
Just musing after tonights gig over a gin and tonic and I'm thinking Heads and Cabs are more popular than combos (I could be wrong). What is your preference and why?
  • sw67sw67 Frets: 232
    Combo - mine is small and light. Had head / cab back in the day but my amp sits out at home so needs to look nice ( wife said )
  • shaunmshaunm Frets: 1633
    No combo projects like a big 2x12 and certainly not like a 4x12.
    Plus point of the combo is less trips to the car
    Weight doesn’t really come into it for me as my gigging combo has been a 4x10 which is far more of a pain in the arse to carry than a separate head and 2x12.
    I am talking absolute and utter bollocks here though because I’ve just got an ABY pedal again so I can use a Head, Cab and Combo set up.
  • ICBMICBM Frets: 72574
    Guitar - combo.
    Bass - head and cab.
    Because those are the best solutions for the sounds I want and the type of music I play.
  • I love combos. I used to think they were gash, but over time I came to realise combos were cooler :)
    I also love the way certain amps sound better when the mechanical interaction between amp and speaker is more intense. Matchless DC30 for example I think sounds better than the HC30 / 212 cab.
    That’s definitely a factor with valve amps. It’s not good for the valves, but it does improve the sound. (Or not, if you want very tight, focused sounds.)
  • RandallFlaggRandallFlagg Frets: 13958
    edited September 2018
    I have always preferred combos, most of the guitars idols I had as a kid used combos and they are what I started out using (Peavey). I'm using a Mesa Mark V 35 combo at present.
    When it comes to valves though, a small head and cab can avoid the tube rattle that some combos can suffer.
  • vizviz Frets: 10719
  • Head over combo all day long as I use them with IRs and need to get as many as possible into my tiny guitar room :-)
    Link to my trading feedback: http://thefretboard.co.uk/discussion/58787/
  • I've always had combos myself but I feel I should go for a Head ad Cab to try them out. I know it'll be another trip to the car and back for the box but at least the weight will be disbursed between them. ;) It's a consideration I have t think of nowadays unfortunately :(
  • viz said:
    Awful lOL
  • ecc83ecc83 Frets: 1639
    From a purely engineering point of view it is a bit crazy to put valves in a box and expose them to 130dB SPL+ sound levels* and expect them NOT to feedback! There is also a big compromise in cabinet design when it has to hold both amp chassis and speaker. Combos can be a bugger to "de-rattle"!
    Not! That there is much science involved in guitar cabs. There is, or should be in a bass cab and in any case, if you had an SVT with internal amp you would need a forklift instead of a Transit.
    *Mind you, I have always thought that a combo's sound MUST be influenced by the speaker/valve coupling to some degree? Has anyone tried comparing an amp going from internal speaker to a nominally identical external? Easiest to do with two identical combos.
    Dave.
  • IvisonGuitarsIvisonGuitars Frets: 6841
    My back also agrees with this... ;)
    http://www.ivisonguitars.com
    (formerly miserneil)
    viz said:
    Both:
    [Marshall ms-2 with the 412 cab. (loud)]
    In a shop I used to work in, I did that - I had an MS-2 on the counter to test guitars when they came in for work, but I had fitted an extension speaker jack and connected it to a Laney 4x12" which was in the amp display area next to the counter - it wasn't immediately obvious where the sound was coming from so at first it made it look like the MS-2 was making all that noise :). A whole half a watt is quite a lot through an efficient cab!
    Yes, I have - and there's very definitely a 'microphonic' component in the sound even when it isn't obviously whistling or ringing. I was actually experimenting to see why two nominally identical amps sounded different, by ruling out the speakers - but the difference in sound was the same whichever amp section was connected to the opposite speaker, rather than its own.
    Trace Elliot did make an 8x10" bass combo, who knows why! And admittedly the amp section was solid-state, so it probably didn't make a lot of difference to the weight of the cab. It was an unwieldy pig to move though, partly because it was slightly top-heavy.
    Ah! The T Elly might be a bit more practical theses days with SMPSUs and class D!
    Dave.
  • TTBZTTBZ Frets: 2911
    Always head and cab for me from now on. The head version always sounds better through a 2x12 or 4x12 imo. Combos are just a pain in the arse to move as well, even 112s can be heavy.
    Yes this is my thinking too as I'd like a 2x12 cab but from experience a 2x12 combo is just too impractical now :(
  • After a lifetime of using combos, with the odd period of "ghost rattle" from valves or chassis from time to time, I now find myself using low powered combos at home but a head and cab away when playing with drummers. As we're talking a Bluguitar AMP1 and a 1x12 FatCab, there's a big difference in weight that my back thanks me for.
  • randellarandella Frets: 4228
    Head (lunchbox) and cab (small).  If I could carry heavier weights I’d use a Mk. Boogie of some kind but I can’t, so it’s the Bonsai version.
    I’m looking at more and more Helix reviews though...
  • supessupes Frets: 183
    Head and cab. Gigged for years, tried both but i always come back to head and cab. I think it’s the spread of sound you convince yourself is much better with a cab.
  • JD50JD50 Frets: 660
    Every time I pick up my Tremoverb I'm glad it's a head....
