Special = no binding, dots, open humbuckers, mostly batwing. Usually BIG necks.
Special Faded = as Special but with "faded" finish and an ebony fretboard on the early ones (2003 and 2004-ish)
Classic = binding, dots, P90s, batwing.
Standard = binding, trap inlays, covered humbuckers, mostly batwing but some with small guard since 2012-ish.
61 RI = binding, traps, most vintagey neck joint and horn carving, covered humbuckers, small guard and sometimes a maestro trem
Over the last decade they've variously fucked about with that so you have Tribute models which are basically Specials with different pickups, and Standards with P90s.
Essentially, anything called Standard should see you right. Great guitars
Worth considering a pickup upgrade, as they're often specced with the 490r/498t set, which are great for Stereophonics-type rock, but not so subtle for lighter styles. They're actually a great guitar for clean-ish stuff if you put something more PAF-y in there.
And yep I hate the 490/498 pickups - 57 Classics are my fave PAF type
Some of the Standard models since 2012 have come with 57s, but I'm not sure which tbh. You'd have to google n a per-model-year basis (thanks, Henry!)
Necks vary dep on year.
Still trying to work out pup type.
Ace guitars...happy boy!
Neck profile might however be a thing hmm. I like a good round 50s style neck.
My R7 and PRS DGT are my fave necks, closely followed by a Warmoth '59 roundback' neck I have
*just remembered- It was because the neck felt SO long & the whole guitar seemed to be 2" to the left of where I wanted it to be.
I've had 3 SG's (still have 2 of them) and I've had no such issues - I simply use a wide strap.
I have bought two LP’s lately and an SG Standard. and the SG has quickly become my go to guitar in my house. It does everything I need it to do and sounds fantastic!
Don’t discount those 490/498 pickups, they sound great in the SG but yes rubbish in a LP. They clean up quite well too.
Use a large strap and there’s no dive.
Light weight, sounds huge, can do clean, can do rock, can do subtle and has unparalleled upper fret access. Just brilliant.
