https://i.imgur.com/0ImvBvD.jpg
https://i.imgur.com/JJFHKb2.jpg
https://i.imgur.com/HlL9CjR.jpg
https://i.imgur.com/xIJKPYR.jpg
Or is it a case of dont fix it if it isnt broken?
I do it for setup preferences, I play heavier modern music and want a stiffer snappier feel to the guitar(/bass). Increasing the break angle can help with getting that kind of setup, but it depends on the geometry of the guitar and how much break angle it had to begin with.
If you remove it you’ll have to set the guitar up again, but if you have time you could do it as an experiment to see what you prefer on that instrument.
Personally, I actually think they sound *better* with a shim usually, but that may just be because it enables you to set the saddles slightly higher which increases the break angle and the pressure on them.
Swapped it for a stewmac full length shim.
I’ve come across those in a couple of guitars, without any noticeably special results. My feeling is that a ‘traditional’ short shim actually sounds better - one was in a Jazzmaster where the full-length shim was too high, so I replaced it with a standard fibreboard one, and the tone improved noticeably. That’s just one example though.
Personally I think that's nonsense - as is the need for an angled 'wedge' shim - not just because thousands of shimmed vintage Fenders sound fine to great with nothing more than a bit of cardboard or the original Fender fibreboard factory shims in there (they made them specifically, in several thicknesses), but because of this...
http://www.nkforsterguitars.com/wp-content/uploads/2014/01/howe-orme-neck-join.jpg
That's a Howe-Orme neck joint on a NK Forster acoustic. The neck touches the body in only three places - the pin at the back of the heel, and the two adjustable wheels under the fingerboard, which can be used to adjust the neck angle and alignment... and it sounds like a normal acoustic guitar. (Only possibly better!)
