If it is a regular set of humbuckers then it is two solder joins per pickup.
Beauty is in the eye of the beer holder
My trading feedback - I'm a good egg
Still a 2 solder joins per pickup proposition.
Honestly, it will take more time to get the pickups out of the guitar than desoldered.
Anyone taking more than 1-2 hours for a pickup swap is taking the mick.
If it were me doing it I'd quote for worst case but say the likelihood would be more straightforward/cheaper.
Until you dig in you really have no idea what horrors you may meet. we've all been there.
Never mind
I wasn't wanting to criticise as such. Just get more of a sense check.
One of these days I'll get over my hatred of soldering and do it myself. Last time I did any meaningful pickup changing I ended up having to pay someone to rectify my dog-chod of a job.
The original pickups were short-legged for the shallow body and the replacements were long-legged. Holes in the pickguard had to be enlarged for the Jackson screws which had to be shortened after fitting up the pickguard. So I had to dismantle and cut down the screws then reassemble.
I would have had to go some to complete all that plus soldering in under an hour and I'm a retired mechanical engineer.
Join the wires together or hold the wire/component in place so it doesn’t move. Apply heat with the iron first, then touch the solder to the joint. Wait till the solder runs then remove the iron. Simples. It doesn’t take long for the heat from the iron to get into the joint, so don’t leave the iron on too long, but you soon get a feel for what works.
Today, I avoid the cost of a tech to rectify my non-functioning bridge pickup by not using my bridge pickup!
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
