I had a guitar with very rough frets
I bought some 0000 grade steel wool, and gave it a good rub. Pretty messy, and didn't feel very smooth
I tried some 600 grade paper on it, which seemed to help a tiny bit.
After some online reading, I bought a £17 set of 9 micromesh sheets, from 1500 to 12000 grade
After using the first 2, I thought it still looked too unaffected, but surely enough, by the time I got through the grades, it is now lovely and mirror-like.
Should I run through these micromesh sheets on any regularity with my non-faulty guitars as a routine maintenance task?
Should I throw away the steel wool and just start with 600 grade or 1000 grade paper?
Outside and away from flammable objects, obviously...
is it any use for normal DIY?
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
I mostly use the 0000 to quickly polish up frets though, and it's pretty quick. Can you use just a single grade of micromesh for that sort of quick polish, or do you have to run through the grades? If so, what's the closest grade to 0000 steel wool?
The first grade is probably something like 1000 grit sandpaper?? @ICBM
I'm guessing 0000 is like 600 grade sandpaper????
I did read somewhere that wire wool leaves smoother peaks and valleys, but surely going through the grades beyond will take care of that?
when should I use these? for routine maintenance????
Always, unless applying an oil based finish
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
