Micromesh - I'm very impressed. Should I throw away my steel wool?
I had a guitar with very rough frets
I bought some 0000 grade steel wool, and gave it a good rub. Pretty messy, and didn't feel very smooth
I tried some 600 grade paper on it, which seemed to help a tiny bit.
After some online reading, I bought a £17 set of 9 micromesh sheets, from 1500 to 12000 grade
After using the first 2, I thought it still looked too unaffected, but surely enough, by the time I got through the grades, it is now lovely and mirror-like.
Should I run through these micromesh sheets on any regularity with my non-faulty guitars as a routine maintenance task?
Should I throw away the steel wool and just start with 600 grade or 1000 grade paper?
  • paulnb57paulnb57 Frets: 3073
    I love Micromesh amd hate wire wool!
  • ICBMICBM Frets: 72646
    No, set fire to it - much more entertaining :).
    Outside and away from flammable objects, obviously...
  • SteveRobinsonSteveRobinson Frets: 7079
    A 9V battery is a good ignition source
  • axisusaxisus Frets: 28343
    Wire wool still has its uses. Micromesh is amazing though, felt like an amazing find a couple of years ago.
  • Winny_PoohWinny_Pooh Frets: 7802
    I've stopped using steel wool, too messy. Frets get up too 2000P and then a Crimson fret polishing rubber for a quick finish.
  • randellarandella Frets: 4263
    Something I keep meaning to try.  I'm still using sandpaper then steel wool - that selection you mentioned, was it something like this...?
    Also, if you've just levelled frets, what sort of grit do you start at when polishing up?  I have some cloth-backed stuff that's about 300 from memory, and sometimes it feels like it's taking away too much material.
  • ToneControlToneControl Frets: 11975
    that's the exact one
    are the fret polish rubbers an alternative, or something to use as well as micromesh?
    is it no use to me now I have the micromesh set?
    is it any use for normal DIY?
    Thanks, that's useful.  I figured it might be from the price but wanted to check I wasn't looking at something completely different. :)
  • impmannimpmann Frets: 12678
    I’ve got the Stew MAC  fret rubbers and they are very good but I tend to finish off with micromesh pads.
  • CasperCasterCasperCaster Frets: 762
    Micromesh is very useful, and I use regular micromesh for lots of jobs. Just one thing to be aware of, the Micromesh grade scales are unique to these products and are not the same as the 'P' scale, but slightly coarser. For example regular micromesh grade 2400 is approximately P1500.
  • PonchoGregPonchoGreg Frets: 764
    This is interesting... I'm getting a bit fed up of 0000 wool - bit messy and getting micro shavings of it under the skin of my fingers (when I'm too lazy to put gloves on) is a right pain, literally.
    I mostly use the 0000 to quickly polish up frets though, and it's pretty quick. Can you use just a single grade of micromesh for that sort of quick polish, or do you have to run through the grades? If so, what's the closest grade to 0000 steel wool?
    Click here to see me butchering some classic solos!
    the micromesh pack I bought is a lot finer than 0000,
    The first grade is probably something like 1000 grit sandpaper?? @ICBM ;
    I'm guessing 0000 is like 600 grade sandpaper????
    I did read somewhere that wire wool leaves smoother peaks and valleys, but surely going through the grades beyond will take care of that?
    Just to reiterate my other question:
    when should I use these? for routine maintenance????
  • RolandRoland Frets: 8758
    Wire wool leaves behind metal fragments, which inevitably wind up sticking to pickup magnets. Yes, you can wipe them off the fretboard, but you can’t get metal dust out of the air without specialist extraction. I’m happy to use wire wool for applying finishes such as Tru Oil, where the fragments end up in the lacquer. I prefer to use cloth backed abrasives for frets.
     Always, unless applying an oil based finish
    I meant how often should I polish the frets with these?
    YVMV, but I’d only polish frets as the last stage of a fret dress.
    not like, every 2 years or every 5 years then?
  • SargeSarge Frets: 2429
    Whenever the frets feel rough or sticky under the string for me, but you're taking so little metal off you can polish them weekly if you want.
