If the guitar is cheap, the fret wire may be economy shite. Vigorous tapping could deform it.
Try a firm tap with a small hammer, so long as you're accurate and don't hit anything else, all should be good. Sometimes though they just won't be hammered back in. In which case a fret clamp does the trick, also a thin superglue is useful (immediately prior to clamping).
Get thee back to the shop post haste & get them to sort it for you (& shower you with compensatory goodies for your emotional distress).
