Single fret too high
HootsmonHootsmon Frets: 16043
and causing zinging on one string.........how do i tap that fret down bearing in mind i have no proper tools?
tae be or not tae be
  • FunkfingersFunkfingers Frets: 14719
    If the guitar is valuable, you either acquire the correct tools or pay somebody to tackle the job for you.
    If the guitar is cheap, the fret wire may be economy shite. Vigorous tapping could deform it.
  • HootsmonHootsmon Frets: 16043
    Surely i can improvise and bang that bugger in with something soft...........like the cat?
  • KittyfriskKittyfrisk Frets: 19287
    Only if you are prepared for a first aid session, or a trip to A&E...
  • gary_macgary_mac Frets: 66
    Try a firm tap with a small hammer, so long as you're accurate and don't hit anything else, all should be good. Sometimes though they just won't be hammered back in. In which case a fret clamp does the trick, also a thin superglue is useful (immediately prior to clamping).
    it's a brand new guitar so most likely 1 x fret has not seated properly....
    thanks guys  :)
    It's brand new & you want to hit it with a hammer?
    Get thee back to the shop post haste & get them to sort it for you (& shower you with compensatory goodies for your emotional distress).
  • tony99tony99 Frets: 7177
    might not be the fret, the string might have a downward kink in it, take it to your local luthier
    Bollocks you don't know Bono !!
