GLWTS
Please excuse the probable 'newb' questions but...
in the event of wanting to either hook up to something like a Fryette Power Station to provide an FX loop would that be fine if then connecting to an 8 ohm cab given the PS options for variable output impedance?
Also, how is it as a pedal platform for delay, tremolo, modulation etc. if going in front of the amp, rather than through an FX loop?
Thanks!
Good questions @Benm39! The first is beyond my very minimal technical knowledge. I simply plug in and play. In terms of the second, I don’t use too many pedals but I regularly use a tremolo, delay and flanger. They have worked just fine. I think the Carrs are known as good fx platforms.
Others may be able to chip in here. All I can do is possibly what you have already done and research on Google.
@wazmeister May be able to comment (he is very knowledgeable about Carr and has/had a Fryette).
