GONE: Carr Sportsman 1 x 12" combo in tweed - excellent condition
Treewig1Treewig1 Frets: 445
edited August 2019 in Amps £
Carr Sportsman 1 x 12" combo in tweed and Roqsolid padded cover
Volume, Treble, Mid, Bass, and Reverb and “Headroom”
Toobs 2x 12AX7, 2x 12AT7, 2x 6V6GT
19 watts
Solid pine cabinet with floating baffle. Point-to-point circuitry
16 ohm 12" Warehouse G12C speaker
Weight in old money 36.8 lbs
UK voltage
Built in the USA in September 2013
Great condition.  Serviced in 2018 by Geoff Pugh at Volt Amp Co.
https://i.imgur.com/RgxAhhn.jpg
https://i.imgur.com/0g0cGEq.jpg
https://i.imgur.com/Yu4k9hn.jpg
https://i.imgur.com/9Mo3YFO.jpg
https://i.imgur.com/yMaADtJ.jpg
https://i.imgur.com/Sawp624.jpg
  • DanDan Frets: 441
    I think this was my old amp. Sounds superb, good luck with the sale.
  • Treewig1Treewig1 Frets: 445
    Thanks Dan.  I think it was.  I just decided to buy back an old amp of mine and I only need one amp.  Nostalgia is a funny thing!
  • hotpickupshotpickups Frets: 1822
    And was my amp before Dan. Great amps these. Not sure why I sold it tbh. Gas probably
    GLWTS
    edited July 2019
    Thanks.
    Bump
    Bump
    Bump for a choice of livery and speaker
    Bump
    PB
    Bump
    Still here
    Bump
  • JonHoskerJonHosker Frets: 395
    Bump from a Carr amp fan
    Thanks @JonHosker .  A great amp but sadly surplus to requirements since I bought back my old Top Hat.
  • Benm39Benm39 Frets: 718
    edited August 2019
    Hmmm, am very tempted by this! Manual suggests that if required an 8 ohm speaker cab can be connected (albeit designed for a 16ohm load)...
    Please excuse the probable 'newb' questions but...
    in the event of wanting to either hook up to something like a Fryette Power Station to provide an FX loop would that be fine if then connecting to an 8 ohm cab given the PS options for variable output impedance?
    Also, how is it as a pedal platform for delay, tremolo, modulation etc. if going in front of the amp, rather than through an FX loop?
    Thanks!
    edited August 2019
    Good questions @Benm39!  The first is beyond my very minimal technical knowledge.  I simply plug in and play.  In terms of the second, I don’t use too many pedals but I regularly use a tremolo, delay and flanger.  They have worked just fine.  I think the Carrs are known as good fx platforms.
    Others may be able to chip in here.  All I can do is possibly what you have already done and research on Google.
    @wazmeister May be able to comment (he is very knowledgeable about Carr and has/had a Fryette).
  • GadgieGadgie Frets: 96
    Nice
    Many thanks @Treewig1 that all sounds very positive.  The limited research I've been able to do certainly indicates it's a fantastic amp.  Definitely on my shortlist  :3
    Thanks.  Keep in touch
  • I want it ;-)
