Need an energy efficient linear halogen replacement
We turned on our lamp and the smart meter terrified us - we're used to LEDs and this shot up! 150 Watts! Not even ridiculously bright, but a lovely warm glow.
I've found very expensive Philips replacements but at 22 quid (I think this is it... https://www.screwfix.com/p/philips-r7s-linear-led-light-bulb-1500lm-14w-118mm/3307p) it's very expensive! I don't mind paying more for the robustness and the fact it's that much less likely to set fire to a curtain (honestly, the lamp gets bloody warm) but I wouldn't mind knocking a few quid off that... Any experience?
  • Simon_MSimon_M Frets: 542
    If you’re using Screwfix, the LAP brand (their own brand) is pretty good. Haven’t had problems with their led lamps. They’re moving towards having everything own brand labelled as Diall which is to unify across the whole company (Kingfisher group) however it is worth considering that Diall isn’t necessarily the same as LAP and I haven’t got the same experience with those.
    150watts is a lot of energy for lighting these days.
    150watts sounds like a flood light. Have you thought about just buying an led flood light?
  • spark240spark240 Frets: 2086
    If it’s out outside flood just stick a new one in...
    https://www.screwfix.com/p/lap-led-pir-floodlight-black-10w-daylight/767cc
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
    This.
    It's a living room lamp - ceiling facing thing. Provides a lot of light so wouldn't be against a slightly less bright lights...
  • boogiemanboogieman Frets: 12390
    The sparky who did the lights and sockets in our kitchen extension reckoned LAP stuff was generally crap and he wouldn’t fit any of it. I know it’s designed down to a price, for instance I tried their GU10 bulbs once but found they buzzed like a wasps nest if you tried to dim them. I took them back and switched to Phillips which were fine. No idea if the Diall replacements are any better, but somehow I doubt it. You pays your money and takes your choice I guess.
  • ICBMICBM Frets: 72510
    When you’ve got used to the power ratings of LED, the amount incandescents use seems insane, and yet that was entirely normal until only a few years ago.
    I’ve also had a bit of trouble with the LAP GU10s, but their other ones have been fine. I’ve got a right mixture of brands and types though, just whatever seems most suitable for the particular fitting rather than any brand loyalty.
    The biggest is a 13W Philips which replaced a 100W incandescent in a single-bulb fitting in the kitchen, and is actually brighter - not far off what an old 150 would have been. It wasn’t cheap, but I’m sure it’s more than paid for itself.
    edited July 2019
    It depends what product you are buying specifically. A lot of LAP stuff is made by British General who are well respected for electrical equipment and screwfix policy for exchanging stuff is good. Some stuff is garbage but then some of the better know manufacturers make garbage too. I’ve not had a problem with LAP stuff but all tradesmen will have their preferences.
  • Balls. Ordered a 78mm instead of a 118mm.
    Bleh. Back to screw fix tomorrow.
    Aye, I have used some LAP stuff myself in my workshop. It’s ok, but you can see where they’ve cut corners. Their light switches are made of very thin plastic for instance and they crack easily if you over tighten the fixing screws, but then they work out at about 50p each so that’s maybe not a surprise.
