And that's not likely to be the lintel, just a render over the top of it. Beware of "mates" who aren't actually familiar with old fashioned building techniques. That style of render is 1920-1950's
Need an angle grinder with a fine narrow blade to cut at the joint between the brown and pebbles if it really has to come off. Underneath is likely to be either a brick arch or a precast concrete lintel which is very unlikely to have cracked. Do not rush into something which will cause a lot more work down the line.
