Help with outside render
BarneyBarney Frets: 616
Found out my lintol has gone up above the front door ...I have a friend coming to sort it out but there will be damage to my render on the front
Unfortunately the render I need they have stopped supplying , does anybody have any ideas what options I have ...was thinking of a canopy to fit over but not keen on them
Was thinking maybe decorative render it already has bands around the doors
Any ideas anyone ...can't find anything on internet
  • steveledzepsteveledzep Frets: 1176
    This thread needs a picture.
  • BarneyBarney Frets: 616
    Your right :) ..I will do a bit cos don't know how to upload pics
  • hywelghywelg Frets: 4303
    edited July 2019
    What's that I can see in the hole?
    And that's not likely to be the lintel, just a render over the top of it. Beware of "mates" who aren't actually familiar with old fashioned building techniques. That style of render is 1920-1950's
    Need an angle grinder with a fine narrow blade to cut at the joint between the brown and pebbles if it really has to come off. Underneath is likely to be either a brick arch or a precast concrete lintel which is very unlikely to have cracked. Do not rush into something which will cause a lot more work down the line.
    I agree.  A little bit more investigation required.  Unlikely to need a new lintel in my opinion too.
    edited July 2019
    It's the angle bead in the hole ...it used to have a like a drip thing before we got it dashed and that's why we think it's the lintol....cod the front bit was just knocked off...my mates a bricklayer by trade..he is on about investigating it first before by just taking a bit off to see what's going on ...it's just off some of the dash has to come off :)
  • notanonnotanon Frets: 610
    Yep angle grinder first to interrogate as mentioned. If you don't go for a bell cast bead and opt for flat face you can use a small channel cut in the soffit render a few mm wide and deep. That will keep the water away from the building you will see the same technique in older cills. A bell cast won't match that style..
    Thanks for the help everybody :)
