I've started playing with my old drummer and bassist after a 10 year gap. We used to be a big eight piece funk/hip hop band.
Now we are kind of gearing towards more atmospheric ambient mogwai rocky stuff...well trying to. I'm trying to get my head around making as big a sound as possible. I don't want to start lugging around a 4x12 or anything. I was after suggestions really. With the funk stuff it was very minimal playing. I'm keen to explore more counterpoint-slash chord voicings. I'm gonna try to figure out some police stuff and look into larger chord voicings and open string voicings as well.
In terms of gear atm a strat/fuzz/delay and reverb with a 1x12 or 2x12 combo. From what I've read I need to look into reverbs and delays etc.
Playing so hard your specs mist up would seem to be the secret.
JM build | Pedalboard plans
https://youtu.be/6moy_pAW3jU
I haven’t watched that since it came out three years ago but presumably it says something useful.
Have some songs where the bass is busy and you hold it all down, other songs where the bass is all root notes and you get adventurous. Maximise the use of vocal harmonies and other grunts etc. As this increases the number of instruments to orchestrate the piece.
There is nothing wrong with blasting through a rock piece like Ace of spades too, but it is hard to find enough great 3 piece numbers to carry a night.
When I saw Motorhead, by way of comparison and as they've been mentioned, they didn't really work with dynamics as much so songs that are great in isolation became part of ninety minutes of chug chug chug. That's fine if you are Lemmy and people love you but otherwise hard to get away with.
My current band is the first time where I've been the only guitarist with just bass, drums and vocals. Now, with my HSS Strat, I just go between either the bridge humbucker or neck pickup. In fact I've started to use my dual humbucker PRS more, just using the neck or bridge pickups.
Whereas previously I was often just on the top 4 strings (chinking away) these days I often play bigger chords. But there are no hard and fast rules. I judge what feels right based on what's going on around me.
One thing that is noticeable is how dramatic it is if I very briefly stop playing. In the old bigger bands I used to be able to (metaphorically) scratch my nose, but now there's suddenly a big hole in the sound.
If I could get two small valve amps (cough cough origin 20s) with some cabs that might be the trick. I just don't want to take loads of stuff
Another thing that guitarists often overlook... play less notes and let the effects do the work for you.
It kind of depends on what style of music it is. For originals it was never a problem as all the songs were wrote for one guitar and I generally used drone open notes or partial chords to make a solo rather than naked single note lead lines.
If I'm covering a 2 guitar part like Sex on fire I will generally play a single part that's made from the most prominent parts of the 2 parts kind of welded into one if that makes sense. Intelligent delays can help here if the drummer is consistent tempo wise.
SPDX's
If the drummers confident then you can trigger loads of non specific pads of sound from the drums. Imagine your doing Hard to Handle and it comes to the solo .... the drummer hits a pad that contains a static B Hammond organ chord, you solo over the top, sounds big and pretty effortless. I ended up taking this to the max and putting an SPD on the floor and would than record static chords into different pads so I could trigger them while soling over the top. So for the solo in Purple Rain I would hit the first pad for a Bb string chord, then pad 2 for the Gm, then pad 3 for the F and pad 4 for the Eb chord ..... so easy but so effective !!
Try a HX Stomp into the wet amp for your surround sound kinda feel.
And listen to The Jam - masters of the 3 piece band.
