OK, I have a 2016 Gibson SG Standard with P90s and I'm considering changing the pickups for Lollars.
Whilst I'm pretty happy with the existing pickups - I'm wondering if Lollars (or if any other suggestions) will bring something new to the party.
Or am I just pissing in the wind? ;-)
Opinions would be most welcome.
Along with many others, I got Scammed by J Collingridge 'Award Winning' Photographer. Full details about his behaviour on this and other forums can be found on this thread. If you have been Scammed by J Collingridge 'Award Winning' Photographer, let us know and even if you haven't, putting a similar message in your own signature will help us warn others.
In what way are the Gibson pickups failing to satisfy you? Is the control harness hard-wired or PCB?
Greg Koch seems to manage pretty well with a stock example. Not sure what amp he is playing through.
The quickest and cheapest way to perk up the sound would be to change the magnets in the bridge/Treble position pickup. Un-oriented Alnico 5 would introduce some interesting rasp.
In fact it's the exact model which Greg is playing in the vid.
It's not that they're not satisfying me at all, just wondering if there would be any merit in changing - The grass is always greener etc.
The first caveat with the Koch video is that the guitar being demonstrated could possibly have Wildwood spec pickups. Since this is not mentioned as either speech or captions, I have presumed standard pickups.
I have Lollar +5% overwound P90s in my PRS SE Soapbar singlecut guitar. I purchased them pre-owned just to discover what the fuss was about. Tried ‘em. Liked ‘em so much that they have stayed in the guitar ever since.
Lollar certainly builds nice pickups. So do a bunch of UK makers.
I've had a few P90 equipped instruments. The ones that came on my Gibson R6 Goldtop were tremendous, felt no need to swap them out. Same with the Little SIster. The JJ ones are also great in a kind of rounder way, the PRS McCarty goldies were amazing and the bridge on my current Fano SP6 is classic, does pretty much everything I want from a bridge pickup.
Overall I would say that the Lollars are extremely good, crisp, punchy, clear although perhaps a little polite.
Gibsons were excellent. Would I swap them out? Probably not but a little bit of experimentation won't harm.
I've had LPs with Gibson's P90's and LPs with Lollars. The Lollars are, simply, slightly different. They are both good P90s. Personally, I would stick with stock ones.
I've also got a guitar fitted with Mojo A3 magnet P90s - they sound biblically nice.
Would I fit the Mojos to the Gibson? No... because I feel no need to.
The moral - if you like it the way it is, leave it alone and just play the thing.
If a great player, played an epi or a budget guitar we would all say that the tone is in the fingers
I suppose it's good for the guitar-based economy though and keeps us all interested
BUY ANOTHER GUITAR
The Gibson p90s you have at present are probably fine
looks like I’ll be saving a few bob and sticking with the gibbos
I'm thinking of ditching the PCB and getting it wired 50's stylee. Any thoughts from anyone on how this has improved things and suggestions on pots and cap values? The other thing I'm thinking about is a push pull to plunge into Peter Green territory - would this be effective with P90's? I have it on a Chapman ML-2 classic with humbuckers,
Your first obstacle to achieving this will be the output cable format of the P90s. Phase reversal wiring requires one of the pickups to have two-conductor + shield cable. (Coil Start, Coil Finish + Ground for the metal baseplate and any copper foil.)
