Soldering question....
Treated myself to a shiny new Antex 25w iron the other day and after 5 or 6 joins/welds (whatever the term is) the solder wouldn't take to the tip, it would just ball up on the end of the solder wire. I clean the tip before and after every join but can't figure why this would happen, i just use a damp sponge to clean the tip. Could i need copper shavings instead/as well?
  • Make sure that the sponge isn't too wet, you want it just damp.
  • Adam_MDAdam_MD Frets: 3420
    You need to tin the tip before you start using it or you get the exact issue you're having.  Have a look at some youtube videos and buy something like this it makes it really easy to tin the tip.  I bought a little tin a few years ago and have barely had to use it.  This one explains it quite well but if you shop around you'll find some cheaper than this.
    https://www.antex.co.uk/products/spares-accessories/tip-tinner/
  • BeardyAndyBeardyAndy Frets: 716
    edited October 2019
    gary_mac said: Make sure that the sponge isn't too wet, you want it just damp.
    I was worried it was the opposite because the sponge was fairly dry (from a previous days quench) so i made it wetter!
    Adam_MD said: You need to tin the tip before you start using it or you get the exact issue you're having.  Have a look at some youtube videos and buy something like this it makes it really easy to tin the tip.  I bought a little tin a few years ago and have barely had to use it.  This one explains it quite well but if you shop around you'll find some cheaper than this.
    Thanks, will check this out.
  • Danny1969Danny1969 Frets: 10418
    Are you using leaded solder or lead free ?
    Lead free needs a hotter iron
    When you get a new tip tin it as it heats up the very first time ...should then be fine.
  • ICBMICBM Frets: 72414
    Don't use standard lead-free if you can possibly avoid it - the added-silver type is far better, in fact if the silver content is high enough (3% or more typically) it works as well as leaded solder. It's quite a lot more expensive but once you've seen the difference you won't want to use non-silver solder again.
    I use the silver solder too it's much easier to use than regular lead free.
  • I've used both lead and lead free, I think not tinning it first use could well be my issue. Lets hope i can bring it back. :/
