https://www.antex.co.uk/products/spares-accessories/tip-tinner/
I was worried it was the opposite because the sponge was fairly dry (from a previous days quench) so i made it wetter!
Adam_MD said: You need to tin the tip before you start using it or you get the exact issue you're having. Have a look at some youtube videos and buy something like this it makes it really easy to tin the tip. I bought a little tin a few years ago and have barely had to use it. This one explains it quite well but if you shop around you'll find some cheaper than this.
Thanks, will check this out.
Lead free needs a hotter iron
When you get a new tip tin it as it heats up the very first time ...should then be fine.
