Help With Laptop Issue (Again) Please.
BellycasterBellycaster Frets: 5854
edited November 2019 in Off Topic
The last 2 times I have inserted my USB Flash Drive, I have had a BSOD with "DPC WATCHDOG VIOLATION" Message. The first time I thought it may have been a one off, but now it's twice I need to know what's going on.
The USB Drive is used regularly, every week for me to back up stuff that's in "Documents" on my PC. It's worked fine for a few years (4 years maybe). Why all of a sudden is it having a mare?
I've left it plugged into the port and will probably keep it in there until I know what to do.
Obviously I'm also worried that when I next start up the laptop with the USB already plugged in, it might freak out upon start up?
Do you guys know a fix? Is it the port that knackered?
I've spotted a couple of Youtube vids but don't know if they have the exact same "cause" of the problem and I don't want to screw anything up.
It's Windows 8.1 BTW!
Thanks.
Only a Fool Would Say That.
  • KittyfriskKittyfrisk Frets: 18757
    I'm not an oracle where Windows is concerned, but you aren't alone.
    Try doing a search on  'windows bsod "dpc watchdog violation" usb insertion'
    You'll get more results than you can shake a stick at.
    It's a bit outside my experience, as I have never knowingly violated a watchdog with an insertion or otherwise  :o
    Good luck  ;)
  • TTonyTTony Frets: 27497
    4 years (regular?) use out of a USB drive isn’t so bad.
    Get a better backup medium!
    Quite regular, yes. I've had one USB Stick 13 years and it's still going. What other back up mediums are there? Thanks.
  • Oh that old message.
    It means you've searched for "hairy milfs big boobs" too many times and you've worn out your hard drive.
    You got my favourite Category...Spot On! ;)
  • bodhibodhi Frets: 1334
    Do you only back up to USB?
    Maybe consider something like Google Drive or Microsoft's OneDrive, in addition?
  • Lucky guess ;)
    What other backup media ...
    Depends on how precious the content is.
    If you’ve got the internet connection; one of the Cloud services (though it’ll cost).
    If not, a USB HDD, or a couple of them so you can apply a proper backup generational system.
    I use RAID enabled NASs - 2 of them, just to be sure.
    You don't really back up properly unless you have multiple copies in multiple locations.
    I use a combination of a cloud storage service syncing to/from my pc, a separate nightly backup to another cloud service, and then periodic manual backups to external USB drives for when Skynet becomes self-aware.
  • Thanks guys, I inserted the USB into a different port before turning on the Laptop and it hasn't freaked out the computer, so I may just abandon that port. May leave the USB in permanently or only plug in/pull out while the Laptop is off. I'll probably buy a spare too.
