Hi all
After some deliberation I am seriously considering getting a Squire Bullet Telecaster. This is on the basis that it's cheap enough to knock about and hopefully upgrade and learn a few skills, while not taking a risk on the second-hand market.
My question is, is it easily upgradable? I am thinking of the following over a period of time:
Bridge changed to three brass saddles - is this possible on a through body model? (this is something I'd do simply because I like the look)
Locking tuners
New nut (graphtec maybe)
New electronics
Would a Bullet allow these mods? I see that the body is slightly shallower than the Affinity, does that pose any problems?
You may ask why not spend more and go up the range and avoid spending on parts? well, I want to learn a few basic skills and if I did spend more I think I'd prefer to get a MIM Fender model. A Bullet is within my range as far as ready cash goes, anything more and I'd be into long-term saving up or finance territory.
Martin
So yeah your idea is sound in principle with a bit of research on your part.
I've not changed a bridge so can't comment on that.
I would say that fitting a new nut isn't as simple as it seems. Well it probably is as simple but nut files to do the job properly are very expensive. So if you are not looking to invest in those then it might be better to get someone else to do that bit.
I'd do the things that involve screws, solder etc - anything that may result in a part being rendered useless (ie a nut) I will get done properly
Feedback
I watch Phillip McKnight on YouTube and find his videos to be excellent and make things seem doable, and he always refers to StewMac. The prices on there appear to be in dollars when I look (and select the UK option).
Would love to see how you get on
I also found that when it came to ordering pups and parts the good folks at Axetec took the time to make sure I was ordering what I needed and in the correct amounts. They also furnished me with wiring diagrams as well. I'm sure they are not alone in giving great customer service but as I've only used them I can't comment on other suppliers.
Nuts are cheap, a decent set of nut files isn't.
I should consider this actually, filing nut slots and filing frets are the two things I don't do myself at the moment.
Feedback
I'm also unsure which is "best" - toploader or through body. Personally I like the through body style myself when looking at the stock guitars, but that's on the cheaper Bullet rather than the Affinity - wonder why that is.
Feedback
If not I'd look for a used bullet, don't see the point in getting a shiny new one to pull it apart. You might be able to get one that already has some mods on it that will save you time/effort/money...
It isn't free, but I reckon you could recover your membership costs fairly easily.
Or team up with some mates looking to buy tools, to offset the costs?
https://www.stewmac.com/StewMAX/StewMAX_1-Year_Membership.html?utm_campaign=20190303smxuk&utm_medium=email&utm_source=promo&utm_content=20190303smxuk
I would go for a used guitar - I'd ask on the sales part if anyone had one when the time is right. I guess the point of getting a new one is that they don't cost much new (depending on your view of what's expensive) and you know, as someone inexperience, it will be close to OK (ie not faulty or bashed/ dropped) out of the box.
I may move the post too... thanks for the suggestion.
