So this is strange. I have some quiet time at home tonight so I thought I'd try out my in progress small pedal board tonight. Discovered a very odd buzzing issue, most noticeable when I have the Big Muff but it's still there when I disconnect that completely.
Basically I had a Whammy plugged into a different plug socket, not connected in any way to the other mini board, when I touch the switch on the Whammy it increases the buzz on the other signal path!
Video evidence:
Really weird, does it with any of the pedals upon further inspection albeit quieter (obviously given the gain on the muff).
Do I need to get my house completely rewired?! Why on earth would it do this??
Excuse any mess you can see in the background on the video as it's a work in progress...
Plugged in on the window plug is the big extension lead, with the Digitech modeller, the Trex fuel tank, two monitor speakers, the mixer, and a sound bar thing which I can remove and still have the same issue
soundcloud.com/thecolourbox-1
But maybe if we can suss it out somehow we could find answers.. neo..
Electric guitar is way more work than it's worth
Worth a try anyway.
I went with a fanless PC this time round and in the oasis of calm and quiet this has created I can hear that one of my monitors has a subtle hum that never goes away, even with nothing plugged in.
In the course of faffing about with all this I've noticed that my Mark V and JCM 800 have both developed a hum when run the normal way into a cab with the masters high that I'm sure wasn't there before (still there even with nothing plugged in, gets worse with all knobs all the way up), when the JCM did it I thought it might be due for the caps replacing but can't see why both amps would suddenly need that doing at the same time.
Considering getting an electrician to install an independent ground for the studio so as to be absolutely sure nothing else in the house/buildings is interfering (I'm giving a particularly suspicious glance at the fan/pump etc in the boiler room).
Also worth taking a deep breath and reminding myself it's probably all fine for a home studio.
I've not tried my current guitar through a computer yet but previous guitars have had the usual bizarre computer interference noise also. The other issue is Pod Farm only seems to work with the Line 6 interface but that interface is terrible and latency is too much, so it's a while other rigmarole to have two interfaces plugged in and a Daw project open just to host it with a different input etc etc that I just want to throw everything out of the window
I have unplugged everything off the extension by the window except the gsp (ie monitors not plugged in). With pedals plugged in by the door, connected to the gsp....noise.
I've also tried a TC Teleport thing with a ground lift switch. Both positions = noise.
I tried disconnecting the gsp and using the pedals straight into the mixer. Noise.
Bizarrely at one point the noise changed as I lifted the black square box thing half way along the power supply cable to the mixer so I've moved all that away from everything. Still noise.
What the hell is going on???
Two of the pedals are new but one isn't. Other old pedals make no difference.
