2020 is the year I hope to finally get my hands on a Kemper. Main use for teaching as it will have different amps for different types of songs I'm doing from Fender cleans to JCM800 to high gain 5150 sounds. Perfect for what I need to do.
What are my output choices then to use it then?
I know it can run into a speaker cab, with the power amp version I believe, but can I use the 1x12 combo speaker in my DSL5c amp? If I don't get the power amp version can I use the actual combo amp to power the speaker? I have a 4x12 but it'd be too loud for home use I would think.
If I run it into monitors which I use for playback in lessons (playing to audio/backing track jamming etc) would I need a mixer to feed both signals?
You don't need a mixer, you can use a cheap Focusrite USB Interface and use the digital mixer, or you can go straight out into monitors and just balance the sound with the volume on the speakers.
The other option of running into monitors is also a possibility though, if I get that interface thing.
When I used a mate's Line 6 Pod Pro it went out of the mono L into the front of the amp head (a Laney) then the usual speaker into cab. Bit weird but it worked for him.
How many cables do I need to be running? And where from the Kemper into the return? The cab out?
It bypasses the preamp section of the DSL - meaning you can control the volume but the preamp and tone controls of DSL don't come into play.
Guitar - Kemper input - Kemper main out - Return of the DSL loop. 2 leads.
So if I get one already with a power amp is the set up different?
And the one without:
Biggest difference is that top left speaker output bit. As the DSL has a detachable speaker jack this is where it goes into I expect. I will probably want one with a power amp if I get back into gigging and play through cabs.
I presume I will turn the cab sim option off?
I have thought about it running it out of monitors too but for the reasons above I prefer an actual speaker cab.
Live I like to use a real cab and send the full Kemper signal to FOH.
I’d strongly recommend a powered Kemper if you can.
And yes I think I will have to stump up that extra £300 or so for the powered version!!
https://www.thefretboard.co.uk/discussion/165309/fs-kemper-profiller-and-yamaha-dxr10-and-accesories#latest
I did the original method of trying to use the combo amp speaker by connecting out the red "speaker output" into the combo speaker, but I got no sound. Surely this is the same way as me using a normal guitar cabinet?
Next I did the FX loop method, so speaker cable from "Main output (L)" into the return of the DSL FX loop. Reconnected detachable speaker cable into the DSL and I got sound working!
But why couldn't I get get any sound from going straight into the DSL? Have I missed a trick here in the output settings? Cab sim was turned off and I was fiddling about with other knobs so much I can't remember what the other settings were. But what should they be? Or do I have to use a combo's FX loop should I want to use the speaker?
