Brown Tortoise shell pickguard, Axerus Ethereal Neck pickup, S90 middle single coil, Matching nickel cover for the Dimarzio Evo and all new electronics(Had Gibson 500A pots and a Jap style 5 way in)
https://i.imgur.com/wMqZkvX.png
https://i.imgur.com/PXjOCEq.jpg
Not sure what colour I'm going to spray the body just yet, will make a last minute decision once I've got the body ready for paint
Quick question - how do you plan on removing the finish from the 'claw' marks behind the trem?
Nice project, btw
Adam
Are you planning to strip and refinish the body ?
So currently stripping the body and will do a sand on the bigger flat areas from 400 up to 1200, I think I might use Rustoleum painters touch spray to finish the body, no idea if it needs a primer and/or clear coat though
Hopefully have some time on the weekend to do some more stripping on the body
Feedback
https://imgur.com/gallery/UMI1PrC
Only going to spray primer on Saturday if the weather's good and hopefully there aren't too many issues to try sand out
Not sure if you can see from this last photo but there a surface of the moon in this one spot, I suppose some more sanding is required
• Youtube - https://www.youtube.com/@Goldeneraguitars
