Hi
I have a jackson kelly KE5FR, which has a Floyd Rose FRT-O2000 tremelo. I have been having issues with tuning stability which i had put down to some wear on the knife edges.
I took it to my local guitar tech to have it properly set up and the knife edges sharpened (which was specifically asked for and charged). They gave it back saying there were no issues.
I have been playing it and continue to have tuning issues. I’ll go through the process of tuning until perfect with the nut open, locking and then fine tuning again. One song later and every string is a quarter step down with only light tremelo use.
Before i go back and start making noises about being ripped off i want to make sure that it’s not something benign. I have no experience with floyds and have only ever had hard tail guitars. What I can’t work out is whether, with new strings, you still need to stretch them like you do on a regular guitar - i just changed strings on my firebird with locking steinberger gearless tuners and still had to pull and stretch the strings loads before it stayed stable so i suspect there’s a similar settling in process even with double locking. But when i try to stretch on the floyd by pulling the string up it ends up popping out of the bridge slot.
Any help would be much appreciated!
many thanks
Richard
https://www.youtube.com/watch?v=ums1cdg6r6M
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Block the trem (front or back). So the angle of the bridge needs to be correct, and I normally use a deck of playing cards jammed in between the trem cavity on the back, and the sustain block. You can also do it by placing cards or a battery under the bridge on the front. I like the back as it's less likely to damage the finish. It's important to make sure the claw holding the springs is level with the cavity. i.e, it's not tighter/closer to the body on one side.
The I tune the guitar normally using the headstock tuners. If I've taken enough tension of the springs (as I'm doing it from the back), then the bridge does not move. I tune, stretch, tune and then I'm good.
I remove the cards, the bridge lifts, causing all the strings to go sharp, but by the same amount. I then adjust the trem springs by equal amounts (in my case tightening as I've blocked from the back), and when the bridge gets to the correct angle, the guitar's in tune.
Then lock off the string clamps, and I'm good to go.
If you block off the trem at the front of the guitar, then the adjustment of the spring tension is the opposite.
https://www.sweetwater.com/sweetcare/articles/floyd-rose-setup-guide/
Once a Floyd is properly locked, that can't happen - they will still expand and contract, but can't move at either end so they remain in tune once back at the original temperature.
It’s only big temp changes that can throw it out and I use my Trem A LOT at weekly rehearsals and gigs.
A few days and much experimentation later I am still having issues. I've stretched the hell out of the strings (which now no longer pop out at the bridge), and I can get it to stay perfectly in tune when I'm just playing normally, but one even vaguely dive-bombish push on the bar and everything goes out. Never the same way. Sometimes the bottom strings go sharp and the top stays in tune, just now the bottom stayed stayed vaguely in tune (A is a bit sharp) and the G-E are very flat.
String gauge is 9-46 in Eb tuning. Here's a pic of the springs: https://www.dropbox.com/s/ij63odxlt84uoux/unnamed.jpg?dl=0
Am I at the 'storm in and demand an explanation' point yet? Am I kidding myself that a floyd will ever stay in tune and should just block the trem?
Okay - try this:
2) remove middle spring
3) tighten the two screws that hold the claw until the trem is once again parallel to the body and the guitar is back in tune
What you are doing is getting the system balance with the springs under as much tension as is available for the string gauge and tuning. The angling in of the springs just helps add a little more tension.
If the strings are going out of tune in different directions it’s slipping at the nut clamps. Do you have them done up tight enough? Do you have them fitted correctly? The ridge on the clamp should be parallel to the strings.
