https://www.stewmac.com/Luthier_Tools/Tools_by_Job/Tools_for_Fretting/Pressing/Fret_Press_Caul_with_5_Fret_Press_Inserts.html
With a little insert into into your drill press.
TBH, a hammer is still handy to tidy it up, but the caul does most of the work.
My small drill press is standard 43mm collar so just need to find something to use like you have to grip the caul.
Ah!! Nice to have that luxury - so I might "chuck" the new fret caul in the Fobco instead of the little Wolf press - that will definitely work !!
Need to make a neck support now... its endless the first time isn't it ?
At least I'll have everything ready to go and the next build will be much quicker.
Made a Heath Robinson fret bending jig last night which worked OK.
Rather disappointed with the single action rod that arrived for the other build I have started......think I will make my own instead
I used door runner/roller for mine - they came "pre-grooved" too, so the fretwire sits in them nicely. It could really do with a handle on one of the bolts to make turning a little easier, but it works.
