Index finger injury - Can't play guitar
Slash'N'burnSlash'N'burn Frets: 162
edited August 2020 in Technique
My left hand index finger suddenly started getting painful and sore, to the point where I struggle to move it and can't properly use that hand.
I don't know exactly what has caused it, as it didn't get trapped, hit or overextended. A couple of days beforehand I was using some heavy extension ladders outside my house, and they are quite a stretch to get them to full extension, releasing and setting the locking catches overhead is quite awkward - but I didn't feel any pain or discomfort at the time, it only  started a couple of days after.
Initially the pain seemed to be right from the knuckle to the tip of my finger, and very tender to touch along on the right side of the finger, but oddly not around the other sides. I couldn't bend it. Fastening a seatbelt or opening a packet was impossible without avoiding use of the index finger. There was no visible swelling or redness though.
Followed NHS advice of rest & ibuprofen etc, but soon stopped the ibuprofen as I was concerned I would forget and do more damage if the pain was numbed (I'm left handed, but play right handed)
3 weeks have passed and it has slowly improved a little, pain has eased and I can bend/flex it a bit but not fully curl it into a fist.
I tried to very gently play guitar (or mimic the movements)  I can feel a twinge if I fret a note with my index finger - but the worst is that it will not go anywhere near the curled position for an open C chord or partial barre across strings 1-2 or 1-3 , I don't want to make things worse.
I'm 40 and have been playing for 20 years, but probably only average an 1 hour playing time a week if i'm lucky, so hopefully the guitar is not the cause. Never had any hand problems until now.
Sorry for the long thread!
Has anyone had a similar experience?
Did it get better on its own with time? how long did it take?
Any benefit from seeing a Doctor/Physio etc?
Is it likely to be an issue with a tendon, or one of the joints the tendon slides through?  I've tried to look up medical advice for this injury online but not found anything similar, all seems to be things like trigger finger (locking) or injuries from a break or serious sprain.
Thanks in advance.
«13
  • Arthritis? Mine came out of nowhere. Maybe worth seeing a physio.  Some recommend a regular daily dose of Ibuprofen unless you have a condition which reacts badly to it (asthma etc).
    'Vot eva happened to the Transylvanian Tvist?'
  • RolandRoland Frets: 8731
    Yes. Your GP is the place to start.
  • Could be a good opportunity to brush up on your slide guitar..
  • MusicwolfMusicwolf Frets: 3663
    edited February 2020
    I very much doubt it.  After all, this is a guitar related problem and is best addressed by consulting other guitarist on a web forum.  I wouldn't be bothering with these, so called, Doctors who think that they are qualified to make a diagnosis and prescribe treatment just because they've completed some kind of extended first aid course.
  • Did you whack your elbow, or sleep on it? Could be cubital tunnel? Definitely worth seeing a doc or a proper physio.
    What I meant was, will an NHS GP be able to do anything for me at this stage, given funding crisis etc, priority of patients with far worse problems.
    Not doubting the skills of Doctors & Physios, just wanted to know other people's experiences with these injuries, and their experiences going to their Doctor.
    I didn't see the point going to my GP in the first week, but yes I will go and see my GP and at least start the ball rolling.
    I've just had a quick read about Cubital tunnel. Not whacked elbow, I do sleep with a bent elbow but on my right side. Thanks, I will get it checked out.
  • poopotpoopot Frets: 9099
    Hurty finger is no excuse not to play!!!!
    https://youtu.be/biK2Ga1brAA
  • JAYJOJAYJO Frets: 1527
    I hurt my forefinger punching someone like a big girls blouse. I hit them with the front part of my finger just after the nail. Didnt feel it at the time and there was no sign of any damage but it hurt like hell for weeks. Luckily it was my strumming hand.
     I will send the head in next time as my hands are worth far more to me theses days...
  • Talk to a doctor before whatever's going on gets worse.  Guitar's not the priority here imo.
    Can I ask how old you were when it started?
    I verry much doubt it.  After all, this is a guitar related problem and is best addressed by consulting other guitarist on a web forum.  I wouldn't be bothering with these, so called, Doctors who think that they are qualified to make a diagnosis and prescribe treatment just because they've completed some kind of extended first aid course.
    I went to a GP with arthritis in my fretting hand forefinger.  She told me it was a deformity that happens so some people with age but it would settle down and wouldn't affect my ability to play guitar.  To put it mildly, this was bollocks. I got far more realistic advice from guitarists on forums.
    OK, this was perhaps an unusual degree of incompetence, but I've seen other doctors since and none has been able to suggest anything that actually helps, as opposed to being able to give me a name for it. It’s not their fault if there's nothing can be done, but it’s a reminder that going to the doctor won't necessarily help.
    So of course, go to your doctor but don't think you're necessarily going to get solutions and don't rule out other sources of information: affected guitarists will often have thought much longer and harder about this issue than most doctors.
    I've been relatively lucky:  I've had this issue for many years now, and although it causes problems with playing they are relatively minor (half barres are difficult, sliding a half barre is completely out of the questions,  bending note with my forefinger is more or less a no-no, vibrato with the damanged finger has to be kept to a minimum, and even fretting an open C chord is difficult because it's hard for me to get enough curl on my index finger). My fear was that it would deteriorate and/or spread to other fingers but, touch wood, so far the only other finger affected is the right hand forefinger and it only needs to be able to hold a plectrum.
    So arthritis obviously isn’t good news but it’s not necessarily as bad as you first imagine.
  • jpfampsjpfamps Frets: 2734
    Or take up lap steel!
  • ColsCols Frets: 7059
    Given the circumstances, most likely some form of tendonitis.  Make an appointment to see your GP.
    In the meantime, start taking the ibuprofen again and avoid using the finger as much as possible (not easy with an index finger, I know).  As well as being a painkiller, ibuprofen reduces inflammation.
    Your GP might not actually be able to do much more in terms of initial treatment (other than maybe splinting it to prevent further movement to allow it to rest), but they can refer you on to a specialist or physiotherapist for further investigation and treatment.
  • When I was 20 I crushed my hand in a motorcycle accident and had to have my bones rebuilt in my fret hand, including plates put into my index finger. My knuckle in my hand is now about 2cm further back than the rest as they had to rebuilt it from an eggshell fracture. My left index finger is now about 2cms short than it used to be and only bends as far as the knuckle on my thumb.
    I spent ages agonising trying to play open chords with it, in the end I just started fretting the chords with my other 3 fingers for a C, G, etc. Feels weird at first, but didn't take too long to get used to it. Also using some diminished chords
    Has the benefit of freaking other guitarists out as well... 'WTF is wrong with your had', haha.
    Vid shows what I mean, excuse the poor audio, it was a long time ago.
  • BezzerBezzer Frets: 586
    @Slash'N'burn you have my sympathy!  I had the same last year across my whole left hand, and my pinky and ring fingers were basically non-functional for a bit.
    Definitely see a Doc.  On one hand if it's something serious/permanent they'll be able to tell you.  Equally if it's NOTHING serious or permanent they can also tell you.
    Mine was basically a "sports injury" and I was told to rest for 8 to 10 weeks.  I had an important gig in the time period so had a problem, he was able to confirm though that although it wouldn't help I wouldn't make it worse I would just hurt like hell afterwards ... he was very, very right.
    But yeah, get checked.  One way or another it's best to know!
    But yeah, get checked.  One way or another it's best to know.
    Thanks. Do you think yours was caused by playing guitar, or other activity? Did you get completely back to normal?
    I've had a long wait for a Doctor's appointment, I'm booked in for Monday.
    A week has passed (4 weeks now) and my index finger has gradually improved a little bit each day. Less pain, able to curl it more, now sometimes noticing a slight 'click' in the last joint when I bend it. Not able to use it for opening things or carrying even something light though. Restricting guitar playing to only using my 2nd/3rd/4th fingers (basically doing light triads, with picking patterns for a few minutes here and there.)
    Yeah, I think it was a combination of things but playing was a major factor in it. I overstretched I think, at a basic level.
    i have recovered completely now, but it did take a lot of rest.
    Good luck with the Doc on Monday. Hopefully they can set your mind at ease a bit.
  • HoofHoof Frets: 494
    Had a very similar pain in the exact same spot a while ago. It started during a quite intense period of practicing (after only playing at rehearsals/gigs for a while). Mine went on for about 3 months and was gradually getting worse until one day I just pulled the tip of my finger on a certain way, there was a very odd (but not painful) pop and the pain disappeared in an instant.
    My Doc said similar to yours, it was an injury and that it would get better itself in time. She said that the gradual improvements were a good sign. As there wasn't any swelling she couldn't say what type of injury it was, advised to keep it moving and use it but well within limits of pain, and go back in 4 weeks if not improving.
    The last couple of weeks it has improved gradually again, I was able to play my Les Paul the other day without any pain (7 weeks after it first started) I was careful to warm up though and didn't go crazy, but was able to do partial barres, unison bends, vibrato etc.  which cheered me up immensely :)
    Only advice I can give to others now is to really look after your hands!  When not playing guitar, don't abuse them with bad technique for things you do at work/taking junk to the tip/DIY etc. - don't overload or overstretch your fingers.
