I have a pickup that has a coil tap and normally the extra windings would be brought in by a push switch that switches between the full pickup and the tap.
Is there a way to possibly wire it up so that the extra windings are gradually brought in with a pot? So instead of either full or tapped, it would start tapped then it would be like a "boost" control that gradually gets louder and louder?
Obviously it wouldn't actually introduce the extra windings gradually, it would introduce them all but with a lot of resistance at first and the resistance would gradually decrease as the pot is turned?
https://www.seymourduncan.com/blog/the-tone-garage/guitar-wiring-explored-the-spin-a-split-mod
For it to work properly you need a Log pot, but it doesn’t matter much if it’s 250K or 500K.
So just for clarification, it's not a split humbucker but a tapped single coil.
So could you just go over again what connects to what for that one?
