https://www.guitarplayer.com/gear/review-quilter-tone-block-202
From whisper quiet to ear-splitting volume. Clean headroom for days. Great EQ Option to use XLR-out if you fancy it, and weighs a whopping 1.5kgs and is small enough to fit into a gigbag. Your back will thank you in years to come!
Should leave about £500 of your budget for a decent cab.
A 70s Marshall Superbass would be another good valve choice - later JMP ones are still well inside that budget, but make sure it's a 4-input not 2... 2 is a better bass amp but not so good for guitar.
But I would probably go for a Quilter or other high-quality solid-state amp for that job.
Feedback
Not as good as the EZG, I've owned/own both and the Dr Z is a beast. Clean, clear, full, bassy and neutral. Never found a pedal that didn't work superbly well. With a 1987 its not quite as good. Some pedals can be a bit hard on the ear (Red Snapper for one)
PA Hire and Event Management
Son has one and with his drive pedals sound really good.
