Best amp head for clean and pedals?
AbiF24AbiF24 Frets: 0
I'm looking to upgrade my gigging rig to a head and cab. I run the amp clean and stack distortions and I like a nice fat clean sound. Budget is up to 1000 pounds (UK) for the whole rig. Any suggestions? Needs to be able to gig with.
«13
  • StefBStefB Frets: 2355
    edited February 2020
    Laney Lionheart L50H if you can find one, and the matching 2x12 or 4x12.
    A rig for life and the bonus of a superb drive channel too, even if you’ll never use it, and footswitchable reverb.
  • lukedlblukedlb Frets: 488
    A used kelly 50 watt head from the 60s/70s. Lots of headroom. Super cleans. Simple amp. Dirt cheap.
  • WhistlerWhistler Frets: 322
    Mesa Boogie is known for the dirty channel but I have used one for years for its clean channel. With so many EQ knobs and sliders I can dial in whatever type of clean sound I am after.
  • If you're getting all of your drive from pedals then I'd get something like a Quilter Tone Block...
    https://www.guitarplayer.com/gear/review-quilter-tone-block-202
    From whisper quiet to ear-splitting volume. Clean headroom for days. Great EQ Option to use XLR-out if you fancy it, and weighs a whopping 1.5kgs and is small enough to fit into a gigbag. Your back will thank you in years to come!
    Should leave about £500 of your budget for a decent cab.
  • hywelghywelg Frets: 4303
    Dr Z EZG. No question. Need to pair it with a good 2x12 cab
  • ExorcistExorcist Frets: 604
    sounds mental, but I ran a 100 watt Laney AOR clean channel cranked, gain low, any gain/fuzz pedal I threw at it sounded godly. And you will never run out of volume/headroom.
  • brooombrooom Frets: 1175
    Blackface bandmaster or bassman?
  • ICBMICBM Frets: 72483
    Bassman especially, but unless you get a repro or a replacement output transformer with multi-impedance taps it's limited to 4 ohms - it will run safely at 8, but you lose quite a lot of the fullness.
    A 70s Marshall Superbass would be another good valve choice - later JMP ones are still well inside that budget, but make sure it's a 4-input not 2... 2 is a better bass amp but not so good for guitar.
    But I would probably go for a Quilter or other high-quality solid-state amp for that job.
  • Jonathanthomas83Jonathanthomas83 Frets: 3472
    I couldn't have said it better...except to consider the L20H too. Both are superb. You'll also be left with £600-700 change if you get the head second hand!
  • John_AJohn_A Frets: 3775
    So many options, really depends what sort of base clean sound you are looking for.  Pretty much how I used to run my JTM45 which I loved.  I certainly wouldn't go or a Quilter, they sound awful IMO
    Marshall MG100HD sound great on clean + pedals. And keep the balance for more GAS.
    Feedback
  • Rich210Rich210 Frets: 577
    Any musicman amp. Clean machines. Absolutely love pedals. I've got a few. Recently picked up a 150 watt head for 300 quid. It's awesome.
  • Some form of 4 input Marshall e.g. JTM45 or 1987x
    Not as good as the EZG, I've owned/own both and the Dr Z is a beast. Clean, clear, full, bassy and neutral. Never found a pedal that didn't work superbly well. With a 1987 its not quite as good. Some pedals can be a bit hard on the ear (Red Snapper for one)
  • AlexOAlexO Frets: 1097
    I tried the new Fender Tonemaster Deluxe reverb last week and was really impressed by the clean tones and how it reacted with pedals.
  • Victory V40 + cab
    https://www.gbmusic.co.uk/
    PA Hire and Event Management
    As an L20H owner, it will *not* do big clean sounds. Amazing overdrives, but it just does not have the headroom for the cleans.
  • monquixotemonquixote Frets: 17647
    Puretone!
    Takes pedals like a champ and stupid cheap second hand.
    Marshall origin is great if you like Marshall cleans.
  • I agree with the Marshall Origin.
    Son has one and with his drive pedals sound really good.
  • MikeBMikeB Frets: 176
    Might stretch the budget but I've always loved my Mesa Lonestar for cleans.
