can't find the exact series of this guitar !! need help!!!
hey guys, so I got this guitar from Switzerland but it doesn't look like all blade guitars its very different ,pickups , bridge .... if someone had or saw a guitar like this one let me know I am so curious about this one .
check the link for the pictures
thank you https://postimg.cc/gallery/37x84iycs/
  • TTonyTTony Frets: 27737
    edited February 2020
    You're asking people for help - at least make it a bit easier for them by putting the pics in the thread.  It's not hard ...
  • KittyfriskKittyfrisk Frets: 19129
    Whoa, that is one wonky tuner fitting.
  • Whoa, that is one wonky tuner fitting.
    Based on that then I reckon it must be a Gibson
  • FunkfingersFunkfingers Frets: 14599
    its very different pickups, bridge
    The bridge and tailpiece are inspired by Zemaitis. The pickups are inspired by Danelectro "Lipstick" single coils.
    The battery compartment implies either a switchable signal booster device, a built-in noise canceller or a piezo transducer for faux acoustic sounds.
    Probably a repair performed in a hurry at a gig because the original screw hole was torn out. The correct solution is to fill and redrill.
    Gary Levinson/Blade design HQ was in Switzerland. The guitars were actually manufactured in Japan.
  • Philly_QPhilly_Q Frets: 23242
    Never seen anything like it before.  Presumably it is some obscure Blade model, but I can't imagine the bridge is original, surely Blade/Levinson wouldn't copy something so quirky and distinctive.
  • ICBMICBM Frets: 72741
    lol, beat me to it :).
    There appear to be three holes in the backplate which would correspond with the EQ trimmers on a Levinson VSC circuit - which is active. Those three holes are the only thing apart from the logo which makes me think it has anything to do with Levinson at all... although I could be wrong.
    The wonky tuner is *very* un-Levinson though - unless it's been knocked and then refitted wrongly.
    I think the pickups, scratchplate and control layout do have a slight whiff of the Levinson "modern take on something classic" aesthetic.  But it is quite out-there.
  • AdeyAdey Frets: 2348
    TTony said:
    You're asking people for help - at least make it a bit easier for them by putting the pics in the thread.  It's not hard...
    I can't seem to work out how to do it :-(
    @Adey ;
    It depends on which image host you're using, and also whether you're using PC, Mac, iPad, phone or some other device to use the forum - but there are help threads that cover most options.  Essentially you just need the address of the image and paste it into the text box here using the little page-turned-down icon on the textbox menu bar.
