What TTony did next
After the successful (!) completion of my C1'20 challenge ... what to do next?
Here's a clue ...
Can you see what it is yet?
:D
«13
  • TTonyTTony Frets: 27793
    Bit of a clue - the timber is American White Ash, and that particular piece was what was left after I made some worktop and then cut a chunk out to fit a Belfast sink into ...
    First job; new Bandsaw blade.  I'm going to be working on some heavy and thick wood, so here's a blade made for working on heavy and thick wood.
    Apply blade to wood
    Apply same blade to a different offcut of the same wood and I've now got a body and neck blank.
    Neck is planed and thicknessed.
    Body now bobbin-sanded - nice smooth outline - and marked out for the next stage ...
    And here's the next stage
    And the next stage just about done ...
    Neck needs a headstock, so glue on some wings
    Body needs a top cover, so find some nice old bi-colour Ash, and prep that
    And neck needs a fretboard
    I cut that from a block of beautiful maple that I've had lying around for 10+ years.  Originally bought from the US (when the exchange rate was better!).  In some ways it's a bit daft using it for this build, but then why not.
    More sanding to be done, but getting there;
    Not a bad day's work
    :D
  • PeteCPeteC Frets: 409
    Brilliant update !   Looking forward to seeing more.
    I was inspired by the accuracy and attention to detail of your builds.
    Inspired to see just how far in the opposite direction I could go!
    I'd originally wanted to have a go at doing it start-to-finish in a day, but I had various delays along the way, so that's not going to be possible.  I reckon it's do-able in two days though.
  • MattNovakMattNovak Frets: 907
    Brilliant! The world needs more Firebirds! Judging by the routing you're going fully hollow? That'll be unique. Following with interest and envy :)
    www.theflyingacesband.com
  • paulnb57paulnb57 Frets: 3087
    Great start Tony, watching with interest, you could have used the gearless tuners on it!...
    *You* @MattNovak  ; are building a (proper) Firebird ... and it's looking like a fine job too.
    Mine is more Firebirdesque.
    Or "in the style of a Firebird".
    Or perhaps "influenced by a Firebird".
    Or possibly, just "vaguely reminiscent of a Firebird".
    I wouldn't have needed them all @paulnb57 ;
    Also, prompted to get on and do this after a conversation involving @Roland at the GuitarShow yesterday.
    :D
    :D
    OMG its a UKE!....?
    Nul points.
  • CeeJayCeeJay Frets: 455
    I’ve already got a bass @CeeJay.
    Surely no-one needs more than one bass?
  • guitargeek62guitargeek62 Frets: 4203
    Hmm, judging by the size I’m tempted to say it’s a rather elaborate keyring...
  • the_jaffathe_jaffa Frets: 1813
    Firebird inspired Mandolin?
    Yes , I'm thinking Firebird-esque Mandolin too.....
    ..unless you have some huge forester bits for hogging out !
  • JalapenoJalapeno Frets: 6402
    TTony said:
    <a lot of pics>
    Crikey, you are cracking on at a fair old lick !
    Feedback
  • RolandRoland Frets: 8794
    You can get a lot done when you’re not working for a living
    Not had a lot of workshop time today, but enough to get the fretboard slotted, after a bit more sanding.
    Even after quite a lot  of a bit more sanding, there was still a mark left from the bandsawing.  Quite a deep blade mark in the middle of the board.  Bugger.  Of course, to get rid of that tiny mark, I'd have to sand the *whole* board down to the level of the mark.
    Unless ... the position of the saw blade mark just happened to co-incide with the location of a fret slot
    :D
    (In the photo above, the saw blade mark is where the pencil line is, about 0.5mm to the left of the where the fret saw will cut).
    Well, that was lucky .... or precisely measured
    Board slotted
    Headstock roughly cut to shape now, and the cap is also roughly cut to shape.
    I've got an old Gibson P100 that no-one seems to want, so I'm tempted to use it here.
    It does - just about - fit.
    Hmm, No.
    And more nul points awarded
    I'm just "resting".
    @Roland - if you think back to our conversation on Sunday, and who that conversation involved at one point, you should be able to guess!
    This build isn't quite true to the original ethos, but it *is* built from scrap, leftovers and (the P100) unwanted bits that were lying around ...
