What TTony did next
13»
  • PeteCPeteC Frets: 409
    Great recovery and looking good !
  • TTonyTTony Frets: 27793
    edited March 2020
    It's been a little while since I posted updates on this.
    So, very quickly ...
    It's done!
    Slightly less quickly ...
    Neck fixed to body with a couple of these;
    And body strung through.  You might thing that the string-thru ferrrules are slightly off centre.  Because they are.  The drill bit wandered as I drilled through from the top.
    Bolt heads are recessed into the body, as is the jack socket
    I pondered for a while over how to get the bridge grounded.
    Both the nut and the bridge are simply bolts with the heads cut off.  Here's the nut, part way through being cut into a groove   which will keep it, more or less, in the right place.
    The bridge is exactly the same.  How to get a ground wire to it??
    Drill a hole through the middle of it an  solder a ground wire into the hole!
    That piece of wood was originally going to be the base for the bridge, with a groove cut into it (like the nut).  But, having done that, the action was way way too high, and I ended up carving a groove into the top of the cap instead;
    Both bridge and nut can still be a fair bit lower.
    Pickup hole is plenty big enough to feed the pot & socket through, and the respective holes for those are close enough to the pickup hole for me to use my fingers to get them into the right places.  Just!
    And that's it.
    The bridge is obviously offset deliberately - intonation!!
    It's actually pretty loud acoustically (as you'd expect with that body construction!).    It's all fairly rough & ready.  But then I did it without any plans or drawings and just made it up as I went along with the intention of trying to get it done in a couple of days.
    In total, it's probably taken about twice as long, though most of the extra time was due to me un-doing the various mistakes that I made (quite possibly because I didn't have plans or drawings!).
    I'll probably end up trashing the body and making another one to re-use the neck and other bits.  At some point.
    It was an interesting self-challenge.  Now I'm going back to building some more amps & cabinets.
    Splendid!  Just my kind of off-the-wall project.  Great :)
  • MattNovakMattNovak Frets: 907
    Great work @TTony ; - when are you making the full size version? A semi hollow firebird with through neck would be very interesting....
    www.theflyingacesband.com
    Cheers Andy!
    I hadn't thought of that option @MattNovak! ; At least, not until you suggested it!!  I wonder what timber I've got lying around ....
  • paulnb57paulnb57 Frets: 3087
    TTony said:
    Cheers Andy!
    Told you you shouldn't have sold those Gearless tuners!....
    :D
