Or fit a wood panel on the wall, with appropriate fixings, then screw the Hercules brackets to the wood facia/panel
You could put a separate strip of wood or board that fixes into the vertical studs, which would give you several good anchor points, then fix your wall hangers onto that.
Something like this - https://www.guitargear.net.au/discussion/index.php?topic=50372.15
If you're not sure what you're doing, it could be worth getting a handyman who is competent to do this for you?
Feedback
Once it all dried, I swung my entire body weight from it, so it's more than capable of holding my six guitars.
On plasterboard, I'd go with the others' suggestions and locate the studs to screw into, rather than relying on plasterboard fixings alone.
These work well
Unless your neighbours don't mind having a big wing nut on their bedroom wall.
