... long since forgotten in a dusty corner!
I think this is my oldest surviving self build. I do remember doing it, must be 10+ years ago. It's a semi-hollow Cherry body with a Cherry top and a simple oil finish which has aged really nicely (to my eyes anyway). The self-build neck is Mahogany with a Wenge fretboard.
I plugged it in and was very pleasantly surprised with the (intermittent!) sound. Turned out that the pickups are Iron Gear Rolling Mill and Steel Twin. Really good sound. So good that I thought I'd spend a little time tidying it up.
It's a bit rough around the edges (look at the rear of the the thru-string holes!) and I clearly made the neck before I'd learned the art of "fret levelling". I tidied up (ie re-did) most of the soldering, put some new strings on it, check that it intonates properly (it does, perfectly) and then adjusted the saddle height a little, only to find that the second fret is way too high.
So, today I'll be removing the strings and doing some fretwork! The ends are nicely rounded, so I'm hoping with a bit of levelling that it'll turn into an even nicer player.
Still thinking about the best way to hide those rear string holes ... suggestions please!
I've still got the other half a plank of the Cherry too.
https://graingerguitarparts.com/products/grainger-string-ferrule-block-6-string-108mm-spacing
Although hopefully you can make or find one a bit cheaper. (That said there are others which are even more expensive!)
I've got some bits of aluminium bar that I might be able to work into a ferrule block, or maybe even some hard wood.
Job for after I've done some fretwork!
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
Feedback
I decided to take the guitar completely apart to do that as the electrics weren't that brilliant and the control cavity was a bit shallow too.
Looked at the Grainger ferrule block, but, by the time I buy the block and the templates, it's getting expensive. So I'm going to make something instead. Got some Wenge in the workshop which might just work nicely. Job for tomorrow.
Thanks for the kind comments guys!
I still might get this ferrule block and just make my own templates to fit.
Though it obviously had a pickup swap at some time between 2009 and now.
I'll now finish it properly!!
The fretboard is Wenge.
And I always put my dots in the same position - ever since the first one that I built (on the Bailey course in 2007)
Cheers @icu81b4 - most of the stuff I make is deliberately different - what's the point of making something that I could just buy - so they tend to be a bit marmite!
Excellent work @Graingerguitars - thanks!!
