I want to installed a pair of these on my PRS but fear that I will ruin them so before I do, I have a few questions so would be grateful if someone can confirm something for me:
1 - is it easy as remove old strap buttons and put them in?
2 - which screw do I use, the PRS one or the Schaller ones?
3 - where can I get some fabric/felt to go under the strap lock?
Weirdly, there is no felt under the PRS strap buttons.
Thanks
Erm, I am not familiar with that term, what does that mean?
I plan to get a pair of these
http://www.amazon.co.uk/gp/product/B000960KNW/ref=gno_cart_title_1?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
Then just unscrew the PRS lock, use PRS screw if I can and screw it back in?
I've never owed a PRS but I have put Schaller strap locks on and needed to use their own screws. They tend to be slightly larger than the guitar's own so they can get a bite into the wood. Which is fine but if you remove them you may need to do some minor surgery to get the old strap buttons back in again ( cocktail sticks and wood glue). The straplocks won't work with all straps, at least not without some modification ( they will only accept a quite thin bit of strap) and that can be a PIA. Last, its always worth checking they are in place properly every time you pick up the guitar as the knobbly bits ( technical term) that sit on top of the strap can undo themselves and... well, its not happy.
My first choice is to keep the PRS buttons as they are. However, PRS buttons are VERY low in terms of clearance from the guitar and they are very flat. So it is very hard to get a strap on in the first place nevermind the Dunlop strap lock (which I have), not tried the washer thing though but i've seen that done.
Also, I like to keep my guitar in the case when i am not playing it and PRS cases are design for the guitar and not guitar with strap attached...it's so stupid really !
Plus, I've seen horror stories about people's strap rubbing on the surface of the guitar leaving horrible marks when left on permenently.
So a few reasons why I like to install the locks but of course I do not want to damage the wood in any way.
The screw from the stock button sometimes won't go into the straplock either.
The PRS strap button is modelled on an old Precision Bass string tree. The diameter of the surface that touches the body of the guitar when fitted, is very small.
Schaller Strap Lock buttons are of much greater diameter and it is highly likely that there installation will mark the finish in a way which would be noticeable were you to reinstall the originals (which you might do if you were ever to sell). The V12 finish is very thin and (I am told) quite brittle.
Given that PRS owners like them to be mint, things like this matter.
I am unconvinced that Strap Locks are needed on a PRS. With a properly fitting strap, the standard buttons are very secure. Incidentally, Grolsch washers won't fit.
I do know that once a strap is fitted on a PRS, it is very secure and don't need strap locks.
Perhaps I would just to somehow mod the case as opposed to modding the guitar !
Dont over tighten the schaller strap button and you'll have no problem. I've never had one work loose through use after years of gigging (touch wood!)
As far as the bit that goes on the strap is concerned, they can be difficult to get onto thick straps so I usually trim off a tiny bit of leather around the hole of the strap button. When putting the locking bit on the strap, I grip it with pliers so I can tighen the bolt enough. A bit of thread lock helps here
I can see the reason why PRS stock strap buttons are how they are but I've always found them an utter pain to get a strap on and off, over the flange!!
Actually its a sufficiently dull Friday afternoon in the office that I had looked on the PRS forum and there are people on there who say they use them but, regardless of the guitar, if you do take the strap off frequently then they aren't great.
For home use and keeping an expensive guitar in best condition I probably wouldn't fit straplocks, just a quick glance down that the strap is in place properly. If its for gigging then the possible tiny damage done fitting a straplock would be neither here nor then against the other potential causes of harm.
They also do the felts for a paltry 50p
linky
