Was it dual Tele coils to make a humbucker for each position, as the basic idea? Seems like it would be up Ash's street. (Similar to his brass knuckle design)
I also have a lot of stuff from Mojo these days.
Instagram
Instagram
Instagram
https://www.dropbox.com/s/998txc2v2dohgg7/6abf16_4545c43d7c35402e93c91be14e515309~mv2.jpeg?dl=0
I haven't seen it in the flesh yet, as he still has to do the bridge before he sends them out to me, but the first impressions of the new and improved neck version looks amazing!
It's actually been a really interesting process. Ash was in no 'bitchy' about Bareknuckle but while discussing the things that we both had to say about the originals, from each of our perspectives, it really came to light that the originals weren't that good. I had numerous occasions where the neck pickups came apart from each other, where they were only glued together and they were very 'noisy', as well as being a nightmare to fit and level, due to the mounting screws going through the middle the pickup on the neck and the fixing screws being within the coils on the bridge. I think tech has moved on which helps, as we can now make new top and base plates easily especially for them. Having side lugs may not look quite as neat but will make them much better to fit and maintain and the all in one top plate looks awesome. We've also added a ground plate and Ash has balanced the 3 top strings and 3 bottom with alnico 3 and 5 magnets to create a better range.
I cant' wait to see the bridge pickup done in the next few weeks and then swap a set into a guitar to get an A/B test against the originals. There may be a few more tweaks along the way but the process is feeling good.
The originals had a think brass plate on the bridge pickup, to make it more like a Tele sound, but Ash seems to think that should be steel and that a brass plate wouldn't do anything. So we are going to do a set of each so we can A/B the differences there too.
They look great too. Seems to be a big improvement on build quality.
https://www.dropbox.com/s/ax62mrixgamoj7h/6abf16_ead75684585e41bbb87001827b249002~mv2.jpeg?dl=0
Instagram
Looking forward to hearing them!
