Instagram
I once spent literally months trying to get hold of some stainless steel inserts and machine screws. I was reading about them on American guitar forums, so I was trying to get them in the correct imperial sizes, emailing all these places in the USA which sold industrial fasteners, materials for boat repairs... I'm still on some of their mailing lists.
They're easier to get hold of now.
Anyway, I fitted a set on a Tele, got them in a size which means they look exactly like normal Fender neck screws until you loosen them. The stainless steel polished up nicely with a bit of micromesh. They're fine, but I'm not convinced they make for a tighter fit or anything.
Now, if I frequently had to take a maple neck on and off I'd probably just put some superglue into the holes to harden the threads in the wood.
When I did my - one and only - (maple) neck, I found the brass inserts were too soft and the threads stripped/collapsed as I tried to install them. Stainless steel worked better.
But your woodworking skills are probably far greater than mine!
Managed to get them out again - but now left with a drilled neck and no M4 threaded inserts.
EDIT - have just ordered a kit with stainless steel threaded inserts to see how that goes. Pilot holes are 7mm so I won't have to do any refilling.
The stainless ones I got worked OK, they certainly didn't strip or collapse. Still a couple of nervy moments trying to get them to screw in straight without cracking the wood!
It made me a bit hesitant about doing the same thing again, although I do have quite a lot of spare machine screws and inserts buried somewhere in the junkyard that is my living room.
I'm the same with electronic components stuff tbh - I buy stuff regularly , then find that I have it already somewhere in the "stores".
Once I'd screwed in the inserts - I think I used a bit of dry soap or wax to help them in - it was too difficult to unscrew them again, but I did run a drop of superglue around the top edges where I'd countersunk them. Being very careful not to get it into the internal threads!
I suppose idigbo should be a bit easier to work with than maple, if it's similar hardness to mahogany.
Ebay mark7777_1
