That's why Gibson end strap buttons use a bigger screw for that button.
Is there a particular size of hook I should look out for? I'm thinking mainly about teh thread size as I don't want to oversize that strap button hole too much - it's exactly the type of mistake I would make.
So oil process has been a bit iffy. I applied 2 coats of Crimson penetrating oil to the whole guitar then 3 coats of High Build Oil over 3 days.
The finish was starting to get shiny and glossy but still rough and tacky/sticky to the touch so I decided to give the WezV method a go (to be fair, it's what Ben @ Crimson recommends too). It was a massive fail, removing the blue stain from the front of the body after about 20 seconds so I stopped. I was using Silverline 1200 grit W&D but I've come to the conclusion that the product is mislabelled. I've since get 1500 grit, 2000 and 2500 from Halfords and also checked out their 1200 while in store. All are infinitely smoother than the 1200 Silverline so I can only assume that paper is not right.
I've recovered the finish slightly, managing to get another coat of Royal Blue to take to most of the affected areas and have now applied another 5 coats of High Build since.
I now have a guitar that looks glossy BUT feels sticky and tacky all over. Is this normal at this stage?
I assume I need to fine sand with wet & dry now so my question is whether I should use water or oil on the paper? Will one result in a more abrasive process than the other?
I'm planning to use the 1500, 2000 and 2500, then depending on the feel I may attempt a couple of passes of Car Polish (either AutoGlym Super Resin Polish or the lightest cut Menzerna that I have in the bag), followed by a few coats of wax.
Also, I had a nice subtle blue/purple burst on the back before oiling. That's now just turned to black with the oil - bit disappointed about that.
The back, with a few tack cloth wipe marks.
The back before stain
